I am using GL-MIFI board, and I was wondering if you guys were planning to offer the possibility to install the last version of pyusb package, instead of the very old 0.4.2 version ?
My python can not work on your architecture because it was built on pyusb 1.x, and I am not able to find any resource on pyusb 0.4…2 to make it compatible…
Until 0.4 version, PyUSB used to be a thin wrapper over libusb. With 1.0 version, things changed considerably. Now PyUSB is an API rich, backend neutral Python USB module easy to use.
