Pass WAN connection down to AP?
I have one WAN public IP address, provided by AT&T. I have set the AT&T modem to IP Passthrough mode, and have a Flint 2 as my main router. After that, I also have a Flint 1 (AX-1800) set up as a dumb access point.
The Flint 2 is capable of having two WAN connections at once via load balancing. I have a second public IP address from AT&T that I want to put into use.
My PS5 console is currently connected to my Flint 1 AP via Ethernet cable.
Is there a way that I can pass the second public IP address down to the Flint 1 AP as a direct WAN port? I want to plug my PS5 directly into it for a connection that is not behind NAT. In other words, I want a LAN port on the Flint 1 AP to be a direct to WAN port.
Is it possible to do this?
Seems that you want two IP passthrough.
I have to say it is not working on the router.
Thank you for your reply. So just to confirm, there is no way to assign a public IP address to a LAN port on the Flint 1 being used as an access port?
Only I don't know a solution. Maybe someone else can help.
