Per network bandwidth throttling
Would it be possible to control the wifi speed per network?
For example.
Set Main wifi speed cap to 10Mbps.
Then cap each device connected to 1Mbps
Set Guest wifi speed cap to 500Kbps
Then cap each connected to guest network to 150Kbps.
Is there a plugin that does this?
Thanks
