Phantom Client on turned off radio
Background Information
  • Model: GL Technologies, Inc. AX1800
  • Firmware Version: 4.4.6
  • Firmware Type: release1
Issue
Client list is showing phantom clients on turned off Guest 5G radio, blocking it doesn’t remove the client.
If they are Phantum why block the MAC address. Did the devices connect to this network and you need to go onto the device and forget the network. They are not receiving or transmitting data.
I think when you migrated them to the regular network they first tried to connect to the old guest network then the new network
