Phone link over GL-XE3000
Hey there.
I am not able to connect my windows 11 to my mobile phone on the mentioned router.
Both use the wi-fi, but can't get them to communicate as they do in other routers.
All is updated, Phone link on both ends, router firmware. Any idea what can be the problem?
Thanks for your help!
Windows-Firewall, maybe.
Nope. Disabled windows defender firewall both on private and public networks with the same result.
It must be a router side issue, because I have another wi-fi network with the same SSID/PW on a different (another brand) router so it should behave as it does there.
So, I couldn't connect to GoodCloud either, and then support asked me to check my connection, so I swapped SIMs with my mobile phone, and found out it was a SIM card issue. Swapped it back and continued to work fine. So it is solved. Thanks for your time.
