It is so difficult knowing what is firmware for what. I was use firmware for 300a that have tor and custom gui and also luci. I like this! But when I upgrade now I only have luci.
Also many different numbers like 1 and 2.264 and I don’t know if one will brick the router.
This does not explain nothing. What is “Version 2.264?” Tor is at version 0.2.9.15. So how can I compare 2.264 to 1.4 if versions are not clear? Also it does not explain what this firmware looks like. What GUI? Is there a gui?
You do amazing work on firmware. I only want to have a way to know what the firmware is.
@kyson-lok I don’t understand what this means? “consistent with our standard firmware”? This is why a readme is good. What is “standard firmware”? What is the version scheme?
And where is the log so I know what goes into each one of these files: https://docs.gl-inet.com/en/2/app/tor/ What version of tor what version of openwrt?
I love this project but there is so very much information that many many times I am very confused.
For some other gli router are available 3.00x-1011 as non cloude version. Should i use the gl-ar750-3.002-1011_cloud.bin as newer, with more fixed bugs the * AR750(white), gl-ar750-3.003-0926.bin ? Does the cloud version have additional menue item or is the different of boot not visuell ?
In the meantime I am completely lost in versions. I just bricked my AR300M - obviously with a wrong firmware - f…k.
Which are the latest v3 firmwares for my
Can you please send the exactly correct link to the right versions for my AR300M and AR750?
There is a confusing number of different versions! E.g. several 3.003-0929 in different folders. Thanks a lot.
