Hi, I need to compile “gocr” to openwrt, the problem is that I always fail to do that since there is no info on how to compile that package to openwrt, reading the openwrt wiki page on how to cross compile programs to openwrt also doesn’t help, I’m using openwrt BB on my GL-iNet 6416. The program can be downloaded at http://www-e.uni-magdeburg.de/jschulen/ocr/gocr-0.50.tar.gz Please anyone help me to cross compile that package, I really need it. Big thanks for those who want to help me.
Let me have a check if I am lucky
$ cat OpenWRT/feeds/packages/utils/gocr/Makefile
# Copyright (C) 2006-2015 OpenWrt.org
# This is free software, licensed under the GNU General Public License v2.
# See /LICENSE for more information.
include $(TOPDIR)/rules.mk
PKG_NAME:=gocr
PKG_VERSION:=0.52
PKG_RELEASE:=1
PKG_SOURCE_URL:=http://www-e.uni-magdeburg.de/jschulen/ocr/
PKG_SOURCE:=$(PKG_NAME)-$(PKG_VERSION).tar.gz
PKG_HASH:=df906463105f5f4273becc2404570f187d4ea52bd5769d33a7a8661a747b8686
PKG_MAINTAINER:=Joerg Schulenburg <jschulen at gmxNOSPAM.de> (remove NOSPAM)
PKG_LICENSE:=GPL
PKG_LICENSE_FILES:=LICENSE
include $(INCLUDE_DIR)/package.mk
define Package/gocr/Default
SECTION:=utils
CATEGORY:=Utilities
URL:=https://www-e.ovgu.de/jschulen/ocr/
endef
define Package/gocr
$(call Package/gocr/Default)
TITLE:=Gocr is an OCR (Optical Character Recognition) program
#DEPENDS:=+make +gcc
endef
define Package/gocr/description
GOCR is an optical character recognition program.
It reads images in many formats and outputs a text file.
Possible image formats are pnm, pbm, pgm, ppm, some pcx and
tga image files. Other formats like pnm.gz, pnm.bz2, png, jpg, tiff, gif,
bmp will be automatically converted using the netpbm-progs, gzip and bzip2
via unix pipe.
A simple graphical frontend written in tcl/tk and some
sample files (you need transfig for the sample files) are included.
Gocr is also able to recognize and translate barcodes.
You do not have to train the program or store large font bases.
Simply call gocr from the command line and get your results.
endef
define Build/Prepare
rm -rf $(PKG_BUILD_DIR)/
mkdir -p $(PKG_BUILD_DIR)/
$(TAR) -xzf $(DL_DIR)/$(PKG_SOURCE) -C $(PKG_BUILD_DIR) --strip 1
endef
define Package/gocr/install
$(INSTALL_DIR) $(1)/bin
$(INSTALL_BIN) $(PKG_BUILD_DIR)/src/gocr $(1)/bin/
endef
$(eval $(call BuildPackage,gocr))
