Please improve mobile ui
I'm using the Comet Pro on 1.8.2 Release 1.
But I also use the mobile version of Brave a fork of Chrome.
The ui is not responsive, I have been told before with this request that the kvm app should be the better choice, but the mobile app is lacking extremely on ATX functions and keyboard functions, and also set clipboard because it is still in beta.
For legacy reasons the mobile ui on the web version isn't functioning normally, when I click the side menu and then open the show keyboard.
The right is overflowed and the screen canvas is extremely small, the hamburger on the left disappears which mean I cannot close the left menu, which is furiating in use because I have to reload the page, this happens when Braves widget (default setting) for page grouping is active only for the hamburger menu, the overflowing on the right happens with and without this widget.
I'm unable to control a simple PXE or bios menu, unable to read due to the smaller screen.
Another issue is if I close the top controls, I cannot expand it back....
So I want to request again if this can be fixed, kvms are known especially in the older days to be reliable even in a datacenter/professional aspect, this why I choose to use the wording legacy carefully, it is unacceptable to just only rely on the app, which isn't a optimized wrap of the web ui (which most companies would do to cut on maintenance and resources).
Some data of my environment:
Mobile: Poco X6 Pro
Resolution: 1218*840
Regarding the menu icon disappearing, you could try switching your mobile browser to desktop layout to see if that improves things.
Regarding the small screen, you may try adjusting the view to the Original Pixel
You're right that the current mobile web experience is not where it should be. Improving the mobile web experience is already on our roadmap, and we plan to optimize it.
We've passed your specific feedback along to our team for evaluation as part of this ongoing work.
That said, for the best compatibility at the moment, Chrome browser (including on mobile) is still our #1 recommendation.
