Policy route
I've got a MT6000, two wans, can someone explain to me how can I do a Policy route, like device1 will use wan1 and device2 will use wan2, or connect to a specific ip using wan1 or wan2
May try to add the routes in: Luci -> Network -> Static Route
LAN IP or range (Target) → WAN IP (IPv4-Gateway)
Update:
The policy router feature has not supported in the default firmware, but you can install the third-party plugins to achieve this feature, like mwan3
https://openwrt.org/docs/guide-user/network/wan/multiwan/mwan3
But the GL firmware have default feature for load balance in the 'Multi-WAN', it is automatically loading the traffic to different WAN interfaces. If you require to use the mwan3, probably require removing the kmwan3 first.
