Hi I have tried this with both an AR150 and also with the Mango device i just received, but to no avail … maybe someone can help me!?
WAN IP: 192.168.1.99
LAN IP: 192.168.8.1
I have the AR150 connected to a switch in my local 192.168.1.X network, i would like to access a webpage on 192.168.8.3 (a smarthome device with a webinterface on port 80).
so i updated to the newest firmware (3.005) and added a port forward as follows
name_of_service
internal ip: 192.168.8.3
external port: 8080
internal port: 80
protocol: tcp/udp
status: enabled
i also tried to add the port at “open ports at router” but this didn’t change a thing.
so when i am on my laptop with ip adress 192.168.1.5 and want to connect to 192.168.1.99:8080 this should forward to 192.168.8.3:80 but unfortunately i do not get any connection…
within the 192.168.8.X network it obviously works
if anyone has a hint, i am stuck! thanks
A
