Port forward not working with VPN
Running a commercial wireguard VPN and I have added port forwards for 9009 and 30033, but when I go to https://canyouseeme.org/, it tells me Connection timeout.
In https://canyouseeme.org/, I used the default populated IP (my dedicated IP) and the ports above.
Protocol: TCP/UDP
External Zone: WAN
External Port 30033
Internal Zone: LAN
Internal IP: 192.168.1.122
Internal Port 30033
Enable: Yes
Same for 9009 port
Hello, could you please tell me the product model and firmware version you use? This will help us locate this possible problem
External zone wgclient and then try it again
That worked, thanks!!!
