Hi, I normally use a WRT1900ACS for my network, and I am very happy to have all the features on there working without any issues.
I thought that GL-MT1300 will work even better since the manufacturer is using OpenWRT as stock firmware.
Unfortunately it seems very buggy so far.
I understand that its probably not an easy job to build a router and provide all the features that OpenWRT provides, and that you have a target group to make your business succeed. Which I guess, is less technical people who wants security in an easy way.
I just want to know if you think it is possible that you will get OpenWRT running as smoothly as i does on the WRT1900ACS?
So far I have problems with at leas the following features:
- Wifi repeating shuts off the device when scanning in your UI
- Wifi UI in Luci doesn’t make sence I have 2 b/g/n devices and if I want to create a device I can only give it WEP security
- If I want to SSH into the device I get error - no matching host key type found. Their offer: ssh-rsa - and I can’t successfully change the ssh settings.
- Why do you only offer rsa and not ed25519?
I would be nice if you could spend some time making your hardware work 100% with the the stock OpenWRT with default settings.
I believe that you could make amazing routers when you have the skills to make hardware tailored for the OpenWRT software.
It would be nice to hear from you what your plans is in regards to making OpenWRT fully functional, and in what state you are - so I can know if I should depend on you to make my routers or if I should look somewhere else.
Best regard Martin Maartensson
