Power Bank that won't restart my Beryl AX when plugging/unplugging
I'm currently using an Iniu 10,000 mAh battery to power my Beryl AX when I'm traveling.
I can charge it while using it, but whenever I plug it in or unplug it, the router reboots.
Are there models where this doesn't happen?
The problem is not router, is the powerbank and in specific power delivery (PD) function: If you connect or disconnect any device, powerbank recheck PD capabilities of connected devices, so for a moment it will cut power. If your powerbank supports multiple power ports, same thing occurs if you connect another device to it.
Not that I know of. It’s a common complaint!
I just tried an old Xiaomi 5200 power bank with USB A output, and it didn’t interrupt the power when plugged in to charge. I got excited, until I unplugged the charger - then it paused the output power.
If you find one, let us know!
Powerbanks with independent outputs don’t do this, but they still suffer from the problem of pausing the output if the charging source is cycled.
