I recently bought several GL-AR150 units and they all have a power calibration that limits the power for 802.11n rates to 12 dBm. (b rates @ 16 dBm and G rates at 15 dBm) This is much lower than a group of GL-AR150 units I bought last year that allows 18 dBm for B and the lowest N rate (MCS0).
Was this an intentional change for regulatory or other reasons? It doesn’t look like a per node calibration since all of the new batch have the same restricted values and all of the older batch have the same higher values. Is there anything I can do to increase the power of the higher 802.11n modulations?
alzhao
March 10, 2017, 1:21pm
2
Hi Luke,
Thanks for reporting this problem. This bring to our attention and we put this in high priority to solve.
Can you tell me where you order the new ones? How many did you order? If possible give me your order number. You can send order number to our email service@gl-inet.com
All were ordered through Amazon. There were 4 last year with the 18 dBm setting, then another batch of 4 (one of which had the 18 dBm setting and the other three with 12 dBm), and finally a batch of 10 (8 have been examined and all 8 have the 12 dBm settings). I have easy access to the MAC addresses if that helps.
Example of 12 dBm calibration from /sys/kernel/debug/ieee80211/phy0/ath9k/regdump
0x00a3c0 0x1e1e1e1e
0x00a3c4 0x181a1c1e
0x00a3c8 0x20200020
0x00a3cc 0x20202020
0x00a3d0 0x18181818
0x00a3d4 0x1a181218
0x00a3d8 0x00000000
0x00a3dc 0x00000000
0x00a3e0 0x1e201e20
0x00a3e4 0x1a1a1416
0x00a3e8 0x00001416
Note register 0x00a3d0 giving the power for MSC0-5 of 0x18=24=12dBm
Thanks,
alzhao
March 12, 2017, 4:51pm
4
Hi Luke,
We find the problem. We are very sorry that in a production run (2k units) the calibration process set wrong parameters so the max txpower was set to 16. There were hundreds of units went into retail channel.
The wrong settings caused a little performance drop when the distance is far.
Please contact cs @ gl-inet.com and we can replace these units for you.
kzqc
March 14, 2017, 3:02am
5
Does this affect the AR-300M units as well? If yes, how do I check it to confirm? Thanks.
alzhao
March 14, 2017, 3:27pm
6
No. It doesn’t affect other models.
can you explain why AR150 had the lowest power and weakest link of all tested devices? another calibration process error? my units came with 18dBm
alzhao
April 11, 2017, 4:59pm
8
Actually AR150 is 18dbm and all the other modules is 20dbm.
But AR150 is the most stable one so it is our best model for business.
If I order an AR150 off Amazon, is there a way to know if I’m getting one with the correct power config?
alzhao
August 9, 2017, 11:59am
10
Actually this problem is long time ago and we think the problem has all fixed.
You can refer to @lkoleszar’s post for technical examination.
psyborg
September 12, 2017, 5:05pm
11
these even had completely different regdump range:
why no 0x00a3c0 offset?
0x000000 0x00000000
0x000004 0x00000000
0x000008 0x0000000c
0x00000c 0x00000000
0x000010 0x00000000
0x000014 0x0008010a
0x000018 0x00000101
0x00001c 0x00000000
0x000020 0x00000000
0x000024 0x00000000
0x000028 0x00000000
0x00002c 0x01f400fa
0x000030 0x00020085
0x000034 0x00000005
0x000038 0x0331d040
0x00003c 0x00000000
0x000040 0x00000000
0x000044 0x00000000
0x000048 0x00000008
0x00004c 0x00000010
0x000050 0x00000000
0x000054 0x00000000
0x000058 0x00000000
0x00005c 0x00000001
0x000060 0x00000786
0x000064 0x00190000
0x000068 0x00000000
0x00006c 0x000f0000
0x000070 0x00001080
0x000074 0x00000000
0x000078 0x00000000
0x00007c 0x00000000
0x000080 0x00000000
0x000084 0x00000000
0x000088 0x00000000
0x00008c 0x00000000
0x000090 0x00000000
0x000094 0x00000000
0x000098 0x00000000
0x00009c 0x00000000
0x0000a0 0x81810175
0x0000a4 0x0000038f
0x0000a8 0x0000038f
0x0000ac 0x00c10000
0x0000b0 0x00000000
0x0000b4 0x00000000
0x0000b8 0x00000000
0x0000bc 0x00000000
0x0000c0 0x00000000
0x0000c4 0x00000000
0x0000c8 0x00000000
0x0000cc 0x00000000
0x0000d0 0x00000000
0x0000d4 0x00000000
0x0000d8 0x00000000
0x0000dc 0x00000000
0x0000e0 0x88888888
0x0000e4 0x00000000
0x0000e8 0x12249249
0x0000ec 0x00000000
0x0000f0 0x00000000
0x0000f4 0x00000000
0x0000f8 0x00112574
0x0000fc 0x00000000
0x000100 0x00000000
0x000104 0x00000000
0x000108 0x00000000
0x00010c 0x00000000
0x000110 0x00000000
0x000114 0x00000000
0x000118 0x00000000
0x00011c 0x00000000
0x000120 0x00000000
0x000124 0x00000000
0x000128 0x00000000
0x00012c 0x00000000
0x000130 0x00000000
0x000134 0x00000000
0x000138 0x00000000
0x00013c 0x00000000
0x000140 0x00000000
0x000144 0x00000000
0x000148 0x00000000
0x00014c 0x00000000
0x000150 0x00000000
0x000154 0x00000000
0x000158 0x00000000
0x00015c 0x00000000
0x000160 0x00000000
0x000164 0x00000000
0x000168 0x00000000
0x00016c 0x00000000
0x000170 0x00000000
0x000174 0x00000000
0x000178 0x00000000
0x00017c 0x00000000
0x000180 0x00000000
0x000184 0x00000000
0x000188 0x00000000
0x00018c 0x00000000
0x000190 0x00000000
0x000194 0x00000000
0x000198 0x00000000
0x00019c 0x00000000
0x0001a0 0x00000000
0x0001a4 0x00000000
0x0001a8 0x00000000
0x0001ac 0x00000000
0x0001b0 0x00000000
0x0001b4 0x00000000
0x0001b8 0x00000000
0x0001bc 0x00000000
0x0001c0 0x00000000
0x0001c4 0x00000000
0x0001c8 0x00000000
0x0001cc 0x00000000
0x0001d0 0x00000000
0x0001d4 0x00000000
0x0001d8 0x00000000
0x0001dc 0x00000000
0x0001e0 0x00000000
0x0001e4 0x00000000
0x0001e8 0x00000000
0x0001ec 0x00000000
0x0001f0 0x00000000
0x0001f4 0x00000000
0x0001f8 0x00000000
0x0001fc 0x00000000
0x000800 0x17131400
0x000804 0x26108834
0x000808 0x4088068c
0x00080c 0x03270000
0x000810 0x17131400
0x000814 0xdc39a0a8
0x000818 0x17131400
0x00081c 0x17131400
0x000820 0xc08c5c80
0x000824 0x032fc080
0x000828 0x00000000
0x00082c 0x00000000
0x000830 0x03180000
0x000834 0x03184800
0x000838 0x031803f0
0x00083c 0x00000000
0x000840 0x00000000
0x000844 0x00000000
0x000848 0x00000000
0x00084c 0x00000000
0x000850 0x00000000
0x000854 0x00000000
0x000858 0x00000000
0x00085c 0x00000000
0x000860 0x00000000
0x000864 0x00000000
0x000868 0x00000000
0x00086c 0x00000000
0x000870 0x00000000
0x000874 0x00000000
0x000878 0x00000000
0x00087c 0x00000000
0x000880 0x00000000
0x000884 0x00000000
0x000888 0x00000000
0x00088c 0x00000000
0x000890 0x00000000
0x000894 0x00000000
0x000898 0x00000000
0x00089c 0x00000000
0x0008a0 0x00000000
0x0008a4 0x00000000
0x0008a8 0x00000000
0x0008ac 0x00000000
0x0008b0 0x00000000
0x0008b4 0x00000000
0x0008b8 0x00000000
0x0008bc 0x00000000
0x0008c0 0x00000000
0x0008c4 0x00000000
0x0008c8 0x00000000
0x0008cc 0x00000000
0x0008d0 0x00000000
0x0008d4 0x00000000
0x0008d8 0x00000000
0x0008dc 0x00000000
0x0008e0 0x00000000
0x0008e4 0x00000000
0x0008e8 0x00000000
0x0008ec 0x00000000
0x0008f0 0x00000000
0x0008f4 0x00000000
0x0008f8 0x00000000
0x0008fc 0x00000000
0x000900 0x00000000
0x000904 0x00000000
0x000908 0x00000000
0x00090c 0x00000000
0x000910 0x00000000
0x000914 0x00000000
0x000918 0x00000000
0x00091c 0x00000000
0x000920 0x01ffec00
0x000924 0x00000000
0x000928 0x00000000
0x00092c 0x00000000
0x000930 0x00000000
0x000934 0x00000000
0x000938 0x00000000
0x00093c 0x00000000
0x000940 0x00000000
0x000944 0x00000000
0x000948 0x00000000
0x00094c 0x00000000
0x000950 0x00000000
0x000954 0x00000000
0x000958 0x00000000
0x00095c 0x00000000
0x000960 0x00000000
0x000964 0x00000000
0x000968 0x00000000
0x00096c 0x00000000
0x000970 0x00000000
0x000974 0x00000000
0x000978 0x00000000
0x00097c 0x00000000
0x000980 0x00000000
0x000984 0x00000000
0x000988 0x00000000
0x00098c 0x00000000
0x000990 0x00000000
0x000994 0x00000000
0x000998 0x00000000
0x00099c 0x00000000
0x0009a0 0x00000000
0x0009a4 0x00000000
0x0009a8 0x00000000
0x0009ac 0x00000000
0x0009b0 0x00000000
0x0009b4 0x00000000
0x0009b8 0x00000000
0x0009bc 0x00000000
0x0009c0 0x00000800
0x0009c4 0x00000800
0x0009c8 0x00000800
0x0009cc 0x00000800
0x0009d0 0x00000800
0x0009d4 0x00000800
0x0009d8 0x00000800
0x0009dc 0x00000800
0x0009e0 0x00000862
0x0009e4 0x000008a2
0x0009e8 0x00000000
0x0009ec 0x00000000
0x0009f0 0x00000000
0x0009f4 0x00000000
0x0009f8 0x00000000
0x0009fc 0x00000000
0x000a00 0x00000000
0x000a04 0x00000000
0x000a08 0x00000000
0x000a0c 0x00000000
0x000a10 0x00000000
0x000a14 0x00000000
0x000a18 0x00000000
0x000a1c 0x00000000
0x000a20 0x00000000
0x000a24 0x00000000
0x000a28 0x00000000
0x000a2c 0x00000000
0x000a30 0x00000000
0x000a34 0x00000000
0x000a38 0x00000000
0x000a3c 0x00000000
0x000a40 0x00000000
0x000a44 0x00000001
0x000a48 0x00000000
0x000a4c 0x00000000
0x000a50 0x00000000
0x000a54 0x00000000
0x000a58 0x00000000
0x000a5c 0x00000000
0x000a60 0x00000000
0x000a64 0x00000000
0x000a68 0x00000000
0x000a6c 0x00000000
0x000a70 0x00000000
0x000a74 0x00000000
0x000a78 0x00000000
0x000a7c 0x00000000
0x000a80 0x00000000
0x000a84 0x00000000
0x000a88 0x00000000
0x000a8c 0x00000000
0x000a90 0x00000000
0x000a94 0x00000000
0x000a98 0x00000000
0x000a9c 0x00000000
0x000aa0 0x00000000
0x000aa4 0x00000000
0x000aa8 0x00000000
0x000aac 0x00000000
0x000ab0 0x00000000
0x000ab4 0x00000000
0x000ab8 0x00000000
0x000abc 0x00000000
0x000ac0 0x00000000
0x000ac4 0x00000000
0x000ac8 0x00000000
0x000acc 0x00000000
0x000ad0 0x00000000
0x000ad4 0x00000000
0x000ad8 0x00000000
0x000adc 0x00000000
0x000ae0 0x00000000
0x000ae4 0x00000000
0x000ae8 0x00000000
0x000aec 0x00000000
0x000af0 0x00000000
0x000af4 0x00000000
0x000af8 0x00000000
0x000afc 0x00000000
0x000b00 0x00000000
0x000b04 0x00000000
0x000b08 0x00000000
0x000b0c 0x00000000
0x000b10 0x00000000
0x000b14 0x00000000
0x000b18 0x00000000
0x000b1c 0x00000000
0x000b20 0x00000000
0x000b24 0x00000000
0x000b28 0x00000000
0x000b2c 0x00000000
0x000b30 0x00000000
0x000b34 0x00000000
0x000b38 0x00000000
0x000b3c 0x00000000
0x000b40 0x00000000
0x000b44 0x00000000
0x000b48 0x00000000
0x000b4c 0x00000000
0x000b50 0x00000000
0x000b54 0x00000000
0x000b58 0x00000000
0x000b5c 0x00000000
0x000b60 0x00000000
0x000b64 0x00000000
0x000b68 0x00000000
0x000b6c 0x00000000
0x000b70 0x00000000
0x000b74 0x00000000
0x000b78 0x00000000
0x000b7c 0x00000000
0x000b80 0x00000000
0x000b84 0x00000000
0x000b88 0x00000000
0x000b8c 0x00000000
0x000b90 0x00000000
0x000b94 0x00000000
0x000b98 0x00000000
0x000b9c 0x00000000
0x000ba0 0x00000000
0x000ba4 0x00000000
0x000ba8 0x00000000
0x000bac 0x00000000
0x000bb0 0x00000000
0x000bb4 0x00000000
0x000bb8 0x00000000
0x000bbc 0x00000000
0x000bc0 0x00000000
0x000bc4 0x00000000
0x000bc8 0x00000000
0x000bcc 0x00000000
0x000bd0 0x00000000
0x000bd4 0x00000000
0x000bd8 0x00000000
0x000bdc 0x00000000
0x000be0 0x00000000
0x000be4 0x00000000
0x000be8 0x00000000
0x000bec 0x00000000
0x000bf0 0x00000000
0x000bf4 0x00000000
0x000bf8 0x00000000
0x000bfc 0x00000000
0x001000 0x00000001
0x001004 0x00000002
0x001008 0x00000004
0x00100c 0x00000008
0x001010 0x00000010
0x001014 0x00000020
0x001018 0x00000040
0x00101c 0x00000080
0x001020 0x00000100
0x001024 0x00000200
0x001028 0x00000000
0x00102c 0x00000000
0x001030 0x00000160
0x001034 0x00000000
0x001038 0x00000000
0x00103c 0x00000000
0x001040 0x007ffc0f
0x001044 0x0030fc0f
0x001048 0x00103c07
0x00104c 0x00101c03
0x001050 0x002ffc0f
0x001054 0x002ffc0f
0x001058 0x002ffc0f
0x00105c 0x002ffc0f
0x001060 0x002ffc0f
0x001064 0x00100000
0x001068 0x00000000
0x00106c 0x00000000
0x001070 0x0000018c
0x001074 0x00000000
0x001078 0x00000000
0x00107c 0x00000000
0x001080 0x0008200a
0x001084 0x0008200a
0x001088 0x0008200a
0x00108c 0x0008200a
0x001090 0x00082004
0x001094 0x00082004
0x001098 0x00082004
0x00109c 0x0008200a
0x0010a0 0x0008200a
0x0010a4 0x0008200a
0x0010a8 0x00000000
0x0010ac 0x00000000
0x0010b0 0x00003e38
0x0010b4 0x00000000
0x0010b8 0x00000000
0x0010bc 0x00000000
0x0010c0 0x00000000
0x0010c4 0x00000000
0x0010c8 0x00000bc0
0x0010cc 0x000005e0
0x0010d0 0x00000000
0x0010d4 0x00000000
0x0010d8 0x00000000
0x0010dc 0x00000000
0x0010e0 0x00000000
0x0010e4 0x00000000
0x0010e8 0x00000000
0x0010ec 0x00000000
0x0010f0 0x00000100
0x0010f4 0x00000000
0x0010f8 0x00000000
0x0010fc 0x00000000
0x001100 0x00001102
0x001104 0x00001102
0x001108 0x00001102
0x00110c 0x00001102
0x001110 0x01001002
0x001114 0x01001002
0x001118 0x01001002
0x00111c 0x00201102
0x001120 0x00041102
0x001124 0x00251102
0x001128 0x00000000
0x00112c 0x00000000
0x001130 0x00000000
0x001134 0x00000000
0x001138 0x00000000
0x00113c 0x00000000
0x001140 0x00000000
0x001144 0x00000000
0x001148 0x00000000
0x00114c 0x00000000
0x001150 0x00000000
0x001154 0x00000000
0x001158 0x00000000
0x00115c 0x00000000
0x001160 0x00000000
0x001164 0x00000000
0x001168 0x00000000
0x00116c 0x00000000
0x001170 0x00000000
0x001174 0x00000000
0x001178 0x00000000
0x00117c 0x00000000
0x001180 0x00000000
0x001184 0x00000000
0x001188 0x00000000
0x00118c 0x00000000
0x001190 0x00000000
0x001194 0x00000000
0x001198 0x00000000
0x00119c 0x00000000
0x0011a0 0x00000000
0x0011a4 0x00000000
0x0011a8 0x00000000
0x0011ac 0x00000000
0x0011b0 0x00000000
0x0011b4 0x00000000
0x0011b8 0x00000000
0x0011bc 0x00000000
0x0011c0 0x00000000
0x0011c4 0x00000000
0x0011c8 0x00000000
0x0011cc 0x00000000
0x0011d0 0x00000000
0x0011d4 0x00000000
0x0011d8 0x00000000
0x0011dc 0x00000000
0x0011e0 0x00000000
0x0011e4 0x00000000
0x0011e8 0x00000000
0x0011ec 0x00000000
0x0011f0 0x00000000
0x0011f4 0x00000000
0x0011f8 0x00000000
0x0011fc 0x00000000
0x001200 0x00000000
0x001204 0x00000000
0x001208 0x00000000
0x00120c 0x00000000
0x001210 0x00000000
0x001214 0x00000000
0x001218 0x00000000
0x00121c 0x00000000
0x001220 0x00000000
0x001224 0x00000000
0x001228 0x00000000
0x00122c 0x00000000
0x001230 0x00000000
0x001234 0x00000000
0x001238 0x00000000
0x00123c 0x00000000
0x001240 0x00000000
0x001244 0x00000000
0x001248 0x00000000
0x00124c 0x00000000
0x001250 0x00000000
0x001254 0x00000000
0x001258 0x00000000
0x00125c 0x00000000
0x001260 0x00000000
0x001264 0x00000000
0x001268 0x00000000
0x00126c 0x00000000
0x001270 0x00010000
0x001274 0x00000000
0x001278 0x00000000
0x00127c 0x00000000
0x001280 0x00000000
0x001284 0x00000000
0x001288 0x00000000
0x00128c 0x00000000
0x001290 0x00000000
0x001294 0x00000000
0x001298 0x00000000
0x00129c 0x00000000
0x0012a0 0x00000000
0x0012a4 0x00000000
0x0012a8 0x00000000
0x0012ac 0x00000000
0x0012b0 0x00000000
0x0012b4 0x00000000
0x0012b8 0x00000000
0x0012bc 0x00000000
0x0012c0 0x00000000
0x0012c4 0x00000000
0x0012c8 0x00000000
0x0012cc 0x00000000
0x0012d0 0x00000000
0x0012d4 0x00000000
0x0012d8 0x00000000
0x0012dc 0x00000000
0x0012e0 0x00000000
0x0012e4 0x00000000
0x0012e8 0x00000000
0x0012ec 0x00000000
0x0012f0 0x00000000
0x0012f4 0x00000000
0x0012f8 0x00000000
0x0012fc 0x00000000
0x001300 0x00000000
0x001304 0x00000000
0x001308 0x00000000
0x00130c 0x00000000
0x001310 0x00000000
0x001314 0x00000000
0x001318 0x00000000
0x00131c 0x00000000
0x001320 0x00000000
0x001324 0x00000000
0x001328 0x00000000
0x00132c 0x00000000
0x001330 0x00000000
0x001334 0x00000000
0x001338 0x00000000
0x00133c 0x00000000
0x001340 0x00000000
0x001344 0x00000000
0x001348 0x00000000
0x00134c 0x00000000
0x001350 0x00000000
0x001354 0x00000000
0x001358 0x00000000
0x00135c 0x00000000
0x001360 0x00000000
0x001364 0x00000000
0x001368 0x00000000
0x00136c 0x00000000
0x001370 0x00000000
0x001374 0x00000000
0x001378 0x00000000
0x00137c 0x00000000
0x001380 0x00000000
0x001384 0x00000000
0x001388 0x00000000
0x00138c 0x00000000
0x001390 0x00000000
0x001394 0x00000000
0x001398 0x00000000
0x00139c 0x00000000
0x0013a0 0x00000000
0x0013a4 0x00000000
0x0013a8 0x00000000
0x0013ac 0x00000000
0x0013b0 0x00000000
0x0013b4 0x00000000
0x0013b8 0x00000000
0x0013bc 0x00000000
0x0013c0 0x00000000
0x0013c4 0x00000000
0x0013c8 0x00000000
0x0013cc 0x00000000
0x0013d0 0x00000000
0x0013d4 0x00000000
0x0013d8 0x00000000
0x0013dc 0x00000000
0x0013e0 0x00000000
0x0013e4 0x00000000
0x0013e8 0x00000000
0x0013ec 0x00000000
0x0013f0 0x00000000
0x0013f4 0x00000000
0x0013f8 0x00000000
0x0013fc 0x00000000
0x001400 0x00000000
0x001404 0x00000000
0x001408 0x00000000
0x00140c 0x00000000
0x001410 0x00000000
0x001414 0x00000000
0x001418 0x00000000
0x00141c 0x00000000
0x001420 0x00000000
0x001424 0x00000000
0x001428 0x00000000
0x00142c 0x00000000
0x001430 0x00000000
0x001434 0x00000000
0x001438 0x00000000
0x00143c 0xffffffff
0x001440 0x00000000
0x001444 0x00000000
0x001448 0x00000000
0x00144c 0x00000000
0x001450 0x00000000
0x001454 0x00000000
0x001458 0x00000000
0x00145c 0x00000000
0x001460 0x00000000
0x001464 0x00000000
0x001468 0x00000000
0x00146c 0x00000000
0x001470 0x00000000
0x001474 0x00000000
0x001478 0x00000000
0x00147c 0xffffffff
0x001480 0x00000000
0x001484 0x00000000
0x001488 0x00000000
0x00148c 0x00000000
0x001490 0x00000000
0x001494 0x00000000
0x001498 0x00000000
0x00149c 0x00000000
0x0014a0 0x00000000
0x0014a4 0x00000000
0x0014a8 0x00000000
0x0014ac 0x00000000
0x0014b0 0x00000000
0x0014b4 0x00000000
0x0014b8 0x00000000
0x0014bc 0x00000000
0x0014c0 0x00000000
0x0014c4 0x00000000
0x0014c8 0x00000000
0x0014cc 0x00000000
0x0014d0 0x00000000
0x0014d4 0x00000000
0x0014d8 0x00000000
0x0014dc 0x00000000
0x0014e0 0x00000000
0x0014e4 0x00000000
0x0014e8 0x00000000
0x0014ec 0x00000000
0x0014f0 0x00000000
0x0014f4 0x00000000
0x0014f8 0x00000000
0x0014fc 0x00000000
0x001500 0x00000000
0x001504 0x00000000
0x001508 0x00000000
0x00150c 0x00000000
0x001510 0x00000000
0x001514 0x00000000
0x001518 0x00000000
0x00151c 0x00000000
0x001520 0x00000000
0x001524 0x00000000
0x001528 0x00000000
0x00152c 0x00000000
0x001530 0x00000000
0x001534 0x00000000
0x001538 0x00000000
0x00153c 0x00000000
0x001540 0x00000000
0x001544 0x00000000
0x001548 0x00000000
0x00154c 0x00000000
0x001550 0x00000000
0x001554 0x00000000
0x001558 0x00000000
0x00155c 0x00000000
0x001560 0x00000000
0x001564 0x00000000
0x001568 0x00000000
0x00156c 0x00000000
0x001570 0x00000000
0x001574 0x00000000
0x001578 0x00000000
0x00157c 0x00000000
0x001580 0x00000000
0x001584 0x00000000
0x001588 0x00000000
0x00158c 0x00000000
0x001590 0x00000000
0x001594 0x00000000
0x001598 0x00000000
0x00159c 0x00000000
0x0015a0 0x00000000
0x0015a4 0x00000000
0x0015a8 0x00000000
0x0015ac 0x00000000
0x0015b0 0x00000000
0x0015b4 0x00000000
0x0015b8 0x00000000
0x0015bc 0x00000000
0x0015c0 0x00000000
0x0015c4 0x00000000
0x0015c8 0x00000000
0x0015cc 0x00000000
0x0015d0 0x00000000
0x0015d4 0x00000000
0x0015d8 0x00000000
0x0015dc 0x00000000
0x0015e0 0x00000000
0x0015e4 0x00000000
0x0015e8 0x00000000
0x0015ec 0x00000000
0x0015f0 0x00000000
0x0015f4 0x00000000
0x0015f8 0x00000000
0x0015fc 0x00000000
0x001600 0x00000000
0x001604 0x00000000
0x001608 0x00000000
0x00160c 0x00000000
0x001610 0x00000000
0x001614 0x00000000
0x001618 0x00000000
0x00161c 0x00000000
0x001620 0x00000000
0x001624 0x00000000
0x001628 0x00000000
0x00162c 0x00000000
0x001630 0x00000000
0x001634 0x00000000
0x001638 0x00000000
0x00163c 0x00000000
0x001640 0x00000000
0x001644 0x00000000
0x001648 0x00000000
0x00164c 0x00000000
0x001650 0x00000000
0x001654 0x00000000
0x001658 0x00000000
0x00165c 0x00000000
0x001660 0x00000000
0x001664 0x00000000
0x001668 0x00000000
0x00166c 0x00000000
0x001670 0x00000000
0x001674 0x00000000
0x001678 0x00000000
0x00167c 0x00000000
0x001680 0x00000000
0x001684 0x00000000
0x001688 0x00000000
0x00168c 0x00000000
0x001690 0x00000000
0x001694 0x00000000
0x001698 0x00000000
0x00169c 0x00000000
0x0016a0 0x00000000
0x0016a4 0x00000000
0x0016a8 0x00000000
0x0016ac 0x00000000
0x0016b0 0x00000000
0x0016b4 0x00000000
0x0016b8 0x00000000
0x0016bc 0x00000000
0x0016c0 0x00000000
0x0016c4 0x00000000
0x0016c8 0x00000000
0x0016cc 0x00000000
0x0016d0 0x00000000
0x0016d4 0x00000000
0x0016d8 0x00000000
0x0016dc 0x00000000
0x0016e0 0x00000000
0x0016e4 0x00000000
0x0016e8 0x00000000
0x0016ec 0x00000000
0x0016f0 0x00000000
0x0016f4 0x00000000
0x0016f8 0x00000000
0x0016fc 0x00000000
0x001700 0x00000000
0x001704 0x00000000
0x001708 0x00000000
0x00170c 0x00000000
0x001710 0x00000000
0x001714 0x00000000
0x001718 0x00000000
0x00171c 0x00000000
0x001720 0x00000000
0x001724 0x00000000
0x001728 0x00000000
0x00172c 0x00000000
0x001730 0x00000000
0x001734 0x00000000
0x001738 0x00000000
0x00173c 0x00000000
0x001740 0x00000000
0x001744 0x00000000
0x001748 0x00000000
0x00174c 0x00000000
0x001750 0x00000000
0x001754 0x00000000
0x001758 0x00000000
0x00175c 0x00000000
0x001760 0x00000000
0x001764 0x00000000
0x001768 0x00000000
0x00176c 0x00000000
0x001770 0x00000000
0x001774 0x00000000
0x001778 0x00000000
0x00177c 0x00000000
0x001780 0x00000000
0x001784 0x00000000
0x001788 0x00000000
0x00178c 0x00000000
0x001790 0x00000000
0x001794 0x00000000
0x001798 0x00000000
0x00179c 0x00000000
0x0017a0 0x00000000
0x0017a4 0x00000000
0x0017a8 0x00000000
0x0017ac 0x00000000
0x0017b0 0x00000000
0x0017b4 0x00000000
0x0017b8 0x00000000
0x0017bc 0x00000000
0x0017c0 0x00000000
0x0017c4 0x00000000
0x0017c8 0x00000000
0x0017cc 0x00000000
0x0017d0 0x00000000
0x0017d4 0x00000000
0x0017d8 0x00000000
0x0017dc 0x00000000
0x0017e0 0x00000000
0x0017e4 0x00000000
0x0017e8 0x00000000
0x0017ec 0x00000000
0x0017f0 0x00000000
0x0017f4 0x00000000
0x0017f8 0x00000000
0x0017fc 0x00000000
0x001800 0x00000000
0x001804 0x00000000
0x001808 0x00000000
0x00180c 0x00000000
0x001810 0x00000000
0x001814 0x00000000
0x001818 0x00000000
0x00181c 0x00000000
0x001820 0x00000000
0x001824 0x00000000
0x001828 0x00000000
0x00182c 0x00000000
0x001830 0x00000000
0x001834 0x00000000
0x001838 0x00000000
0x00183c 0x00000000
0x001840 0x00000000
0x001844 0x00000000
0x001848 0x00000000
0x00184c 0x00000000
0x001850 0x00000000
0x001854 0x00000000
0x001858 0x00000000
0x00185c 0x00000000
0x001860 0x00000000
0x001864 0x00000000
0x001868 0x00000000
0x00186c 0x00000000
0x001870 0x00000000
0x001874 0x00000000
0x001878 0x00000000
0x00187c 0x00000000
0x001880 0x00000000
0x001884 0x00000000
0x001888 0x00000000
0x00188c 0x00000000
0x001890 0x00000000
0x001894 0x00000000
0x001898 0x00000000
0x00189c 0x00000000
0x0018a0 0x00000000
0x0018a4 0x00000000
0x0018a8 0x00000000
0x0018ac 0x00000000
0x0018b0 0x00000000
0x0018b4 0x00000000
0x0018b8 0x00000000
0x0018bc 0x00000000
0x0018c0 0x00000000
0x0018c4 0x00000000
0x0018c8 0x00000000
0x0018cc 0x00000000
0x0018d0 0x00000000
0x0018d4 0x00000000
0x0018d8 0x00000000
0x0018dc 0x00000000
0x0018e0 0x00000000
0x0018e4 0x00000000
0x0018e8 0x00000000
0x0018ec 0x00000000
0x0018f0 0x00000000
0x0018f4 0x00000000
0x0018f8 0x00000000
0x0018fc 0x00000000
0x001900 0x00000000
0x001904 0x00000000
0x001908 0x00000000
0x00190c 0x00000000
0x001910 0x00000000
0x001914 0x00000000
0x001918 0x00000000
0x00191c 0x00000000
0x001920 0x00000000
0x001924 0x00000000
0x001928 0x00000000
0x00192c 0x00000000
0x001930 0x00000000
0x001934 0x00000000
0x001938 0x00000000
0x00193c 0x00000000
0x001940 0x00000000
0x001944 0x00000000
0x001948 0x00000000
0x00194c 0x00000000
0x001950 0x00000000
0x001954 0x00000000
0x001958 0x00000000
0x00195c 0x00000000
0x001960 0x00000000
0x001964 0x00000000
0x001968 0x00000000
0x00196c 0x00000000
0x001970 0x00000000
0x001974 0x00000000
0x001978 0x00000000
0x00197c 0x00000000
0x001980 0x00000000
0x001984 0x00000000
0x001988 0x00000000
0x00198c 0x00000000
0x001990 0x00000000
0x001994 0x00000000
0x001998 0x00000000
0x00199c 0x00000000
0x0019a0 0x00000000
0x0019a4 0x00000000
0x0019a8 0x00000000
0x0019ac 0x00000000
0x0019b0 0x00000000
0x0019b4 0x00000000
0x0019b8 0x00000000
0x0019bc 0x00000000
0x0019c0 0x00000000
0x0019c4 0x00000000
0x0019c8 0x00000000
0x0019cc 0x00000000
0x0019d0 0x00000000
0x0019d4 0x00000000
0x0019d8 0x00000000
0x0019dc 0x00000000
0x0019e0 0x00000000
0x0019e4 0x00000000
0x0019e8 0x00000000
0x0019ec 0x00000000
0x0019f0 0x00000000
0x0019f4 0x00000000
0x0019f8 0x00000000
0x0019fc 0x00000000
0x001a00 0x00000000
0x001a04 0x00000000
0x001a08 0x00000000
0x001a0c 0x00000000
0x001a10 0x00000000
0x001a14 0x00000000
0x001a18 0x00000000
0x001a1c 0x00000000
0x001a20 0x00000000
0x001a24 0x00000000
0x001a28 0x00000000
0x001a2c 0x00000000
0x001a30 0x00000000
0x001a34 0x00000000
0x001a38 0x00000000
0x001a3c 0x00000000
0x001a40 0x00000000
0x001a44 0x00000000
0x001a48 0x00000000
0x001a4c 0x00000000
0x001a50 0x00000000
0x001a54 0x00000000
0x001a58 0x00000000
0x001a5c 0x00000000
0x001a60 0x00000000
0x001a64 0x00000000
0x001a68 0x00000000
0x001a6c 0x00000000
0x001a70 0x00000000
0x001a74 0x00000000
0x001a78 0x00000000
0x001a7c 0x00000000
0x001a80 0x00000000
0x001a84 0x00000000
0x001a88 0x00000000
0x001a8c 0x00000000
0x001a90 0x00000000
0x001a94 0x00000000
0x001a98 0x00000000
0x001a9c 0x00000000
0x001aa0 0x00000000
0x001aa4 0x00000000
0x001aa8 0x00000000
0x001aac 0x00000000
0x001ab0 0x00000000
0x001ab4 0x00000000
0x001ab8 0x00000000
0x001abc 0x00000000
0x001ac0 0x00000000
0x001ac4 0x00000000
0x001ac8 0x00000000
0x001acc 0x00000000
0x001ad0 0x00000000
0x001ad4 0x00000000
0x001ad8 0x00000000
0x001adc 0x00000000
0x001ae0 0x00000000
0x001ae4 0x00000000
0x001ae8 0x00000000
0x001aec 0x00000000
0x001af0 0x00000000
0x001af4 0x00000000
0x001af8 0x00000000
0x001afc 0x00000000
0x001b00 0x00000000
0x001b04 0x00000000
0x001b08 0x00000000
0x001b0c 0x00000000
0x001b10 0x00000000
0x001b14 0x00000000
0x001b18 0x00000000
0x001b1c 0x00000000
0x001b20 0x00000000
0x001b24 0x00000000
0x001b28 0x00000000
0x001b2c 0x00000000
0x001b30 0x00000000
0x001b34 0x00000000
0x001b38 0x00000000
0x001b3c 0x00000000
0x001b40 0x00000000
0x001b44 0x00000000
0x001b48 0x00000000
0x001b4c 0x00000000
0x001b50 0x00000000
0x001b54 0x00000000
0x001b58 0x00000000
0x001b5c 0x00000000
0x001b60 0x00000000
0x001b64 0x00000000
0x001b68 0x00000000
0x001b6c 0x00000000
0x001b70 0x00000000
0x001b74 0x00000000
0x001b78 0x00000000
0x001b7c 0x00000000
0x001b80 0x00000000
0x001b84 0x00000000
0x001b88 0x00000000
0x001b8c 0x00000000
0x001b90 0x00000000
0x001b94 0x00000000
0x001b98 0x00000000
0x001b9c 0x00000000
0x001ba0 0x00000000
0x001ba4 0x00000000
0x001ba8 0x00000000
0x001bac 0x00000000
0x001bb0 0x00000000
0x001bb4 0x00000000
0x001bb8 0x00000000
0x001bbc 0x00000000
0x001bc0 0x00000000
0x001bc4 0x00000000
0x001bc8 0x00000000
0x001bcc 0x00000000
0x001bd0 0x00000000
0x001bd4 0x00000000
0x001bd8 0x00000000
0x001bdc 0x00000000
0x001be0 0x00000000
0x001be4 0x00000000
0x001be8 0x00000000
0x001bec 0x00000000
0x001bf0 0x00000000
0x001bf4 0x00000000
0x001bf8 0x00000000
0x001bfc 0x00000000
0x001c00 0x00000000
0x001c04 0x00000000
0x001c08 0x00000000
0x001c0c 0x00000000
0x001c10 0x00000000
0x001c14 0x00000000
0x001c18 0x00000000
0x001c1c 0x00000000
0x001c20 0x00000000
0x001c24 0x00000000
0x001c28 0x00000000
0x001c2c 0x00000000
0x001c30 0x00000000
0x001c34 0x00000000
0x001c38 0x00000000
0x001c3c 0x00000000
0x001c40 0x00000000
0x001c44 0x00000000
0x001c48 0x00000000
0x001c4c 0x00000000
0x001c50 0x00000000
0x001c54 0x00000000
0x001c58 0x00000000
0x001c5c 0x00000000
0x001c60 0x00000000
0x001c64 0x00000000
0x001c68 0x00000000
0x001c6c 0x00000000
0x001c70 0x00000000
0x001c74 0x00000000
0x001c78 0x00000000
0x001c7c 0x00000000
0x001c80 0x00000000
0x001c84 0x00000000
0x001c88 0x00000000
0x001c8c 0x00000000
0x001c90 0x00000000
0x001c94 0x00000000
0x001c98 0x00000000
0x001c9c 0x00000000
0x001ca0 0x00000000
0x001ca4 0x00000000
0x001ca8 0x00000000
0x001cac 0x00000000
0x001cb0 0x00000000
0x001cb4 0x00000000
0x001cb8 0x00000000
0x001cbc 0x00000000
0x001cc0 0x00000000
0x001cc4 0x00000000
0x001cc8 0x00000000
0x001ccc 0x00000000
0x001cd0 0x00000000
0x001cd4 0x00000000
0x001cd8 0x00000000
0x001cdc 0x00000000
0x001ce0 0x00000000
0x001ce4 0x00000000
0x001ce8 0x00000000
0x001cec 0x00000000
0x001cf0 0x00000000
0x001cf4 0x00000000
0x001cf8 0x00000000
0x001cfc 0x00000000
0x001d00 0x00000000
0x001d04 0x00000000
0x001d08 0x00000000
0x001d0c 0x00000000
0x001d10 0x00000000
0x001d14 0x00000000
0x001d18 0x00000000
0x001d1c 0x00000000
0x001d20 0x00000000
0x001d24 0x00000000
0x001d28 0x00000000
0x001d2c 0x00000000
0x001d30 0x00000000
0x001d34 0x00000000
0x001d38 0x00000000
0x001d3c 0x00000000
0x001d40 0x00000000
0x001d44 0x00000000
0x001d48 0x00000000
0x001d4c 0x00000000
0x001d50 0x00000000
0x001d54 0x00000000
0x001d58 0x00000000
0x001d5c 0x00000000
0x001d60 0x00000000
0x001d64 0x00000000
0x001d68 0x00000000
0x001d6c 0x00000000
0x001d70 0x00000000
0x001d74 0x00000000
0x001d78 0x00000000
0x001d7c 0x00000000
0x001d80 0x00000000
0x001d84 0x00000000
0x001d88 0x00000000
0x001d8c 0x00000000
0x001d90 0x00000000
0x001d94 0x00000000
0x001d98 0x00000000
0x001d9c 0x00000000
0x001da0 0x00000000
0x001da4 0x00000000
0x001da8 0x00000000
0x001dac 0x00000000
0x001db0 0x00000000
0x001db4 0x00000000
0x001db8 0x00000000
0x001dbc 0x00000000
0x001dc0 0x00000000
0x001dc4 0x00000000
0x001dc8 0x00000000
0x001dcc 0x00000000
0x001dd0 0x00000000
0x001dd4 0x00000000
0x001dd8 0x00000000
0x001ddc 0x00000000
0x001de0 0x00000000
0x001de4 0x00000000
0x001de8 0x00000000
0x001dec 0x00000000
0x001df0 0x00000000
0x001df4 0x00000000
0x001df8 0x00000000
0x001dfc 0x00000000
0x001e00 0x00000000
0x001e04 0x00000000
0x001e08 0x00000000
0x001e0c 0x00000000
0x001e10 0x00000000
0x001e14 0x00000000
0x001e18 0x00000000
0x001e1c 0x00000000
0x001e20 0x00000000
0x001e24 0x00000000
0x001e28 0x00000000
0x001e2c 0x00000000
0x001e30 0x00000000
0x001e34 0x00000000
0x001e38 0x00000000
0x001e3c 0x00000000
0x001e40 0x00000000
0x001e44 0x00000000
0x001e48 0x00000000
0x001e4c 0x00000000
0x001e50 0x00000000
0x001e54 0x00000000
0x001e58 0x00000000
0x001e5c 0x00000000
0x001e60 0x00000000
0x001e64 0x00000000
0x001e68 0x00000000
0x001e6c 0x00000000
0x001e70 0x00000000
0x001e74 0x00000000
0x001e78 0x00000000
0x001e7c 0x00000000
0x001e80 0x00000000
0x001e84 0x00000000
0x001e88 0x00000000
0x001e8c 0x00000000
0x001e90 0x00000000
0x001e94 0x00000000
0x001e98 0x00000000
0x001e9c 0x00000000
0x001ea0 0x00000000
0x001ea4 0x00000000
0x001ea8 0x00000000
0x001eac 0x00000000
0x001eb0 0x00000000
0x001eb4 0x00000000
0x001eb8 0x00000000
0x001ebc 0x00000000
0x001ec0 0x00000000
0x001ec4 0x00000000
0x001ec8 0x00000000
0x001ecc 0x00000000
0x001ed0 0x00000000
0x001ed4 0x00000000
0x001ed8 0x00000000
0x001edc 0x00000000
0x001ee0 0x00000000
0x001ee4 0x00000000
0x001ee8 0x00000000
0x001eec 0x00000000
0x001ef0 0x00000000
0x001ef4 0x00000000
0x001ef8 0x00000000
0x001efc 0x00000000
0x001f00 0x00000000
0x001f04 0x00000003
0x001f08 0xbadc0ffe
0x001f0c 0xbadc0ffe
0x001f10 0x00000000
0x001f14 0x00000003
0x001f18 0xbadc0ffe
0x001f1c 0xbadc0ffe
0x001f20 0x00000000
0x001f24 0x00000003
0x001f28 0xbadc0ffe
0x001f2c 0xbadc0ffe
0x001f30 0x00000000
0x001f34 0x00000003
0x001f38 0xbadc0ffe
0x001f3c 0xbadc0ffe
0x001f40 0x00000000
0x001f44 0x00000003
0x001f48 0xbadc0ffe
0x001f4c 0xbadc0ffe
0x001f50 0x00000000
0x001f54 0x00000003
0x001f58 0xbadc0ffe
0x001f5c 0xbadc0ffe
0x001f60 0x00000000
0x001f64 0x00000003
0x001f68 0xbadc0ffe
0x001f6c 0xbadc0ffe
0x001f70 0x00000000
0x001f74 0x00000003
0x001f78 0xbadc0ffe
0x001f7c 0xbadc0ffe
0x001f80 0x00000000
0x001f84 0x00000003
0x001f88 0xbadc0ffe
0x001f8c 0xbadc0ffe
0x001f90 0x00000000
0x001f94 0x00000003
0x001f98 0xbadc0ffe
0x001f9c 0xbadc0ffe
0x001fa0 0x00000000
0x001fa4 0x00000003
0x001fa8 0xbadc0ffe
0x001fac 0xbadc0ffe
0x001fb0 0x00000000
0x001fb4 0x00000003
0x001fb8 0xbadc0ffe
0x001fbc 0xbadc0ffe
0x001fc0 0x00000000
0x001fc4 0x00000003
0x001fc8 0xbadc0ffe
0x001fcc 0xbadc0ffe
0x001fd0 0x00000000
0x001fd4 0x00000003
0x001fd8 0xbadc0ffe
0x001fdc 0xbadc0ffe
0x001fe0 0x00000000
0x001fe4 0x00000003
0x001fe8 0xbadc0ffe
0x001fec 0xbadc0ffe
0x001ff0 0x00000000
0x001ff4 0x00000003
0x001ff8 0xbadc0ffe
0x001ffc 0xbadc0ffe
0x004000 0x00000000
0x004004 0x0102420b
0x004008 0x00000000
0x00400c 0x00000000
0x004010 0x00000000
0x004014 0x08000400
0x004018 0x10001000
0x00401c 0x000002fc
0x004020 0x002000ff
0x004024 0x00000000
0x004028 0x00000000
0x00402c 0x00000000
0x004030 0x00000002
0x004034 0x00023f60
0x004038 0x00000000
0x00403c 0x00000000
0x004040 0xbadc00fe
0x004044 0xbadc00fe
0x004048 0x00000000
0x00404c 0x00000000
0x004050 0x00000000
0x004054 0x00000000
0x004058 0x00000000
0x00405c 0x00020000
0x004060 0x00000000
0x004064 0x00000000
0x004068 0x00000000
0x00406c 0x00000000
0x004070 0x00000000
0x004074 0x00000011
0x004078 0xffffffff
0x00407c 0x00000003
0x004080 0x00000200
0x004084 0x00000000
0x004088 0x00000008
0x00408c 0x00000000
0x004090 0x00000001
0x004094 0x00000001
0x004098 0x00000000
0x00409c 0x00000000
0x0040a0 0x00000000
0x0040a4 0x00a0c1c8
0x0040a8 0x00000000
0x0040ac 0x00000000
0x0040b0 0x00000000
0x0040b4 0x00000000
0x0040b8 0x00000000
0x0040bc 0x00000cd0
0x0040c0 0x00000000
0x0040c4 0x00000000
0x0040c8 0x00000000
0x0040cc 0x00000000
0x0040d0 0x00000000
0x0040d4 0x00000000
0x0040d8 0x00000000
0x0040dc 0x00000000
0x0040e0 0x00000000
0x0040e4 0x00000000
0x0040e8 0x00000000
0x0040ec 0x00000000
0x0040f0 0x00000000
0x0040f4 0x00000000
0x0040f8 0x00000000
0x0040fc 0x00000000
0x007000 0x00000000
0x007004 0x00000000
0x007008 0x00000000
0x00700c 0x00000000
0x007010 0x00000022
0x007014 0x0000142c
0x007018 0x00000500
0x00701c 0x00000001
0x007020 0x00000000
0x007024 0x00000000
0x007028 0x00000000
0x00702c 0x00000000
0x007030 0x00000002
0x007034 0x00000002
0x007038 0x000002f8
0x00703c 0x00e04a3d
0x007040 0x00000001
0x007044 0x00000002
0x007048 0x00000002
0x00704c 0x00000003
0x007050 0x00000000
0x007054 0x00000000
0x007058 0x00000000
0x008000 0x406e95e4
0x008004 0xb881ae6c
0x008008 0x00000000
0x00800c 0x00000000
0x008010 0x00000800
0x008014 0x08400b00
0x008018 0x00000700
0x00801c 0x12e0002b
0x008020 0x00000000
0x008024 0x00000000
0x008028 0x00000000
0x00802c 0x00000000
0x008030 0x00000000
0x008034 0x00000000
0x008038 0x00000000
0x00803c 0x00004097
0x008040 0xffffffff
0x008044 0xffffffff
0x008048 0x00000000
0x00804c 0x002d2366
0x008050 0x00000000
0x008054 0x00000000
0x008058 0x00000001
0x00805c 0x000fc78f
0x008060 0xc7ff000f
0x008064 0x00000000
0x008068 0x20000000
0x00806c 0x00002880
0x008070 0x00000310
0x008074 0x00000020
0x008078 0x00000000
0x00807c 0x00000000
0x008080 0x082270e0
0x008084 0x00000000
0x008088 0x00000000
0x00808c 0x00000000
0x008090 0x00000000
0x008094 0x00000000
0x008098 0x00000000
0x00809c 0x0000000f
0x0080a0 0x00000000
0x0080a4 0x02ff0000
0x0080a8 0x0e070605
0x0080ac 0x0000000d
0x0080b0 0x00000000
0x0080b4 0x00000000
0x0080b8 0x00000000
0x0080bc 0x00000000
0x0080c0 0x2a800000
0x0080c4 0x06900168
0x0080c8 0x13881c20
0x0080cc 0x01f40000
0x0080d0 0x00252500
0x0080d4 0x00a00000
0x0080d8 0x00400000
0x0080dc 0x00000000
0x0080e0 0xffffffff
0x0080e4 0x0000ffff
0x0080e8 0x3f3f2424
0x0080ec 0x0001e6ea
0x0080f0 0x000003be
0x0080f4 0x000209e8
0x0080f8 0x009fe1d0
0x0080fc 0x00020000
0x008100 0x00000000
0x008104 0x00000000
0x008108 0x00000052
0x00810c 0x00000000
0x008110 0x00000000
0x008114 0x00000200
0x008118 0x000100aa
0x00811c 0x00003210
0x008120 0x18f0481c
0x008124 0x00000001
0x008128 0x00000001
0x00812c 0x00000025
0x008130 0x00020000
0x008134 0x00000000
0x008138 0x02000000
0x00813c 0x0000ffff
0x008140 0x00000000
0x008144 0xffffffff
0x008148 0x00000000
0x00814c 0x00000000
0x008150 0x00000000
0x008154 0x00000000
0x008158 0x00000000
0x00815c 0x00000000
0x008160 0x00000000
0x008164 0x00000000
0x008168 0x00000000
0x00816c 0x00000000
0x008170 0x18486200
0x008174 0x33332210
0x008178 0x00000000
0x00817c 0x0002e000
0x008180 0xcdc21130
0x008184 0x062051c7
0x008188 0xb3260020
0x00818c 0xd0609098
0x008190 0x8021880c
0x008194 0x51000400
0x008198 0x10762120
0x00819c 0x05508205
0x0081a0 0x0502c404
0x0081a4 0x09b9a030
0x0081a8 0x0f125429
0x0081ac 0x01604001
0x0081b0 0x042d02e2
0x0081b4 0x001d7003
0x0081b8 0x0d842562
0x0081bc 0x01626809
0x0081c0 0x00000000
0x0081c4 0x33332210
0x0081c8 0x00000000
0x0081cc 0x00000000
0x0081d0 0x0000320a
0x0081d4 0x00000000
0x0081d8 0x00000000
0x0081dc 0x00000000
0x0081e0 0x00000000
0x0081e4 0x00000000
0x0081e8 0x00000000
0x0081ec 0x000000ff
0x0081f0 0xffffffff
0x0081f4 0xffffffff
0x0081f8 0xffffffff
0x0081fc 0xffffffff
0x008200 0x002d5000
0x008204 0x002d4c00
0x008208 0x002d3800
0x00820c 0x2e259840
0x008210 0x409318c9
0x008214 0x45b31a04
0x008218 0x0890a0b4
0x00821c 0x80896040
0x008220 0x00003200
0x008224 0x00003200
0x008228 0x00003200
0x00822c 0x0a420282
0x008230 0x0494447a
0x008234 0x0e384551
0x008238 0x0c00a860
0x00823c 0x04844402
0x008240 0x00100007
0x008244 0x0110f3d7
0x008248 0x00000800
0x00824c 0x0001e7ae
0x008250 0x00000000
0x008254 0x00017870
0x008258 0x00000000
0x00825c 0x40000000
0x008260 0x00080922
0x008264 0x9d400010
0x008268 0xffffffff
0x00826c 0x0000ffff
0x008270 0x00000000
0x008274 0x40000000
0x008278 0x003e4180
0x00827c 0x00000004
0x008280 0x00000000
0x008284 0x0000002c
0x008288 0x0000002c
0x00828c 0x000000ff
0x008290 0x00000000
0x008294 0x00000000
0x008298 0x00000000
0x00829c 0x00000000
0x0082a0 0x00000000
0x0082a4 0x00000000
0x0082a8 0x00000000
0x0082ac 0x00000000
0x0082b0 0x00000000
0x0082b4 0x00000000
0x0082b8 0x00000000
0x0082bc 0x00000000
0x0082c0 0x00000000
0x0082c4 0x00000000
0x0082c8 0x00000000
0x0082cc 0x00000000
0x0082d0 0x00000000
0x0082d4 0x00000000
0x0082d8 0x00000000
0x0082dc 0x00000000
0x0082e0 0x00000000
0x0082e4 0x00000000
0x0082e8 0x00000000
0x0082ec 0x00000000
0x0082f0 0x00000000
0x0082f4 0x00000000
0x0082f8 0x00000000
0x0082fc 0x00000000
0x008300 0x00000140
0x008304 0x00000000
0x008308 0x00000000
0x00830c 0x00000000
0x008310 0x00000000
0x008314 0x00000000
0x008318 0x00000000
0x00831c 0x0000010d
0x008320 0x00000000
0x008324 0x00000000
0x008328 0x07966f45
0x00832c 0x00000001
0x008330 0x00000302
0x008334 0x00000700
0x008338 0x00ff0000
0x00833c 0x02400000
0x008340 0x00000700
0x008344 0xaa4a109b
0x008348 0x008f0000
0x00834c 0x00000000
0x008350 0x1af3aa34
0x008354 0x00020004
0x008358 0x80000080
0x00835c 0x00000000
0x008360 0xffffffff
0x008364 0xffffffff
0x008368 0x00000000
0x00836c 0x00000000
0x008370 0x00000000
0x008374 0x000000ff
0x008378 0x00000000
0x00837c 0x00000000
0x008380 0xffffffff
0x008384 0xffffffff
0x008388 0x00000000
0x00838c 0x00000000
0x008390 0xffffffff
0x008394 0xffffffff
0x008398 0x00000000
0x00839c 0x00000000
0x0083a0 0x00000000
0x0083a4 0x0000fa14
0x0083a8 0x000f0c00
0x0083ac 0x33332210
0x0083b0 0x33332210
0x0083b4 0x33332210
0x0083b8 0x33332210
0x0083bc 0x00000000
0x0083c0 0x00000000
0x0083c4 0x00000000
0x0083c8 0x00000000
0x0083cc 0x00000200
0x0083d0 0x000301ff
0x0083d4 0x00000000
0x0083d8 0x00000000
0x0083dc 0x00000000
0x0083e0 0x00000000
0x0083e4 0x00000000
0x0083e8 0x00000000
0x0083ec 0x00000000
0x0083f0 0x00000000
0x0083f4 0x00000000
0x0083f8 0x00000000
0x0083fc 0x00000000
0x008400 0xe0a04b1c
0x008404 0xbe9383c3
0x008408 0x1a8aa488
0x00840c 0x7b166195
0x008410 0x9aac3237
0x008414 0x45d53362
0x008418 0x6b2b00aa
0x00841c 0x34fcf228
0x008420 0x905d9980
0x008424 0x1631da77
0x008428 0x1c7fdbb6
0x00842c 0xc872534d
0x008430 0xecf1192b
0x008434 0x77ecc92b
0x008438 0xfd4ab2f4
0x00843c 0x58a53a9a
0x008440 0xbc06a8de
0x008444 0xbc7ed17a
0x008448 0x34258e93
0x00844c 0xa9708211
0x008450 0x94adf38b
0x008454 0x95a45f78
0x008458 0x3ccd597b
0x00845c 0x68c69860
0x008460 0x21fe00cb
0x008464 0xa21c3f0a
0x008468 0xb21353bb
0x00846c 0x13efe11e
0x008470 0xf80921a7
0x008474 0x516daacd
0x008478 0x84920970
0x00847c 0xe3f26e7c
0x008480 0x55fc798f
0x008484 0xb904a7ce
0x008488 0xcd420824
0x00848c 0xe0c04173
0x008490 0xd6e1be09
0x008494 0x6fe57599
0x008498 0xafe963ed
0x00849c 0xba576145
0x0084a0 0x3bb22688
0x0084a4 0x96c904e5
0x0084a8 0x2a25200b
0x0084ac 0xdf2667dc
0x0084b0 0x00bb6170
0x0084b4 0xb372d976
0x0084b8 0xdeb33870
0x0084bc 0x483bb4e9
0x0084c0 0xbd69bf2f
0x0084c4 0xf91565c1
0x0084c8 0xdd732a99
0x0084cc 0xd1ae0b84
0x0084d0 0xaa552bd8
0x0084d4 0x39076c77
0x0084d8 0x2213daf3
0x0084dc 0x3d4e55d7
0x0084e0 0x1d83347d
0x0084e4 0xb7d3ac92
0x0084e8 0x808bc487
0x0084ec 0x527ae586
0x0084f0 0xaee0f280
0x0084f4 0x295aa271
0x0084f8 0x94cf0bd4
0x0084fc 0x98e62236
0x008500 0x00000000
0x008504 0x00000000
0x008508 0x00000000
0x00850c 0x00000000
0x008510 0x00000000
0x008514 0x00000000
0x008518 0x00000000
0x00851c 0x00000000
0x008520 0x00000000
0x008524 0x00000000
0x008528 0x00000000
0x00852c 0x00000000
0x008530 0x00000000
0x008534 0x00000000
0x008538 0x00000000
0x00853c 0x00000000
0x008540 0x00000000
0x008544 0x00000000
0x008548 0x00000000
0x00854c 0x00000000
0x008550 0x00000000
0x008554 0x00000000
0x008558 0x00000000
0x00855c 0x00000000
0x008560 0x00000000
0x008564 0x00000000
0x008568 0x00000000
0x00856c 0x00000000
0x008570 0x00000000
0x008574 0x00000000
0x008578 0x00000000
0x00857c 0x00000000
0x008580 0x00000000
0x008584 0x00000000
0x008588 0x00000000
0x00858c 0x00000000
0x008590 0x00000000
0x008594 0x00000000
0x008598 0x00000000
0x00859c 0x00000000
0x0085a0 0x00000000
0x0085a4 0x00000000
0x0085a8 0x00000000
0x0085ac 0x00000000
0x0085b0 0x00000000
0x0085b4 0x00000000
0x0085b8 0x00000000
0x0085bc 0x00000000
0x0085c0 0x00000000
0x0085c4 0x00000000
0x0085c8 0x00000000
0x0085cc 0x00000000
0x0085d0 0x00000000
0x0085d4 0x00000000
0x0085d8 0x00000000
0x0085dc 0x00000000
0x0085e0 0x00000000
0x0085e4 0x00000000
0x0085e8 0x00000000
0x0085ec 0x00000000
0x0085f0 0x00000000
0x0085f4 0x00000000
0x0085f8 0x00000000
0x0085fc 0x00000000
0x008600 0x00000000
0x008604 0x00000000
0x008608 0x00000000
0x00860c 0x00000000
0x008610 0x00000000
0x008614 0x00000000
0x008618 0x00000000
0x00861c 0x00000000
0x008620 0x00000000
0x008624 0x00000000
0x008628 0x00000000
0x00862c 0x00000000
0x008630 0x00000000
0x008634 0x00000000
0x008638 0x00000000
0x00863c 0x00000000
0x008640 0x00000000
0x008644 0x00000000
0x008648 0x00000000
0x00864c 0x00000000
0x008650 0x00000000
0x008654 0x00000000
0x008658 0x00000000
0x00865c 0x00000000
0x008660 0x00000000
0x008664 0x00000000
0x008668 0x00000000
0x00866c 0x00000000
0x008670 0x00000000
0x008674 0x00000000
0x008678 0x00000000
0x00867c 0x00000000
0x008680 0x00000000
0x008684 0x00000000
0x008688 0x00000000
0x00868c 0x00000000
0x008690 0x00000000
0x008694 0x00000000
0x008698 0x00000000
0x00869c 0x00000000
0x0086a0 0x00000000
0x0086a4 0x00000000
0x0086a8 0x00000000
0x0086ac 0x00000000
0x0086b0 0x00000000
0x0086b4 0x00000000
0x0086b8 0x00000000
0x0086bc 0x00000000
0x0086c0 0x00000000
0x0086c4 0x00000000
0x0086c8 0x00000000
0x0086cc 0x00000000
0x0086d0 0x00000000
0x0086d4 0x00000000
0x0086d8 0x00000000
0x0086dc 0x00000000
0x0086e0 0x00000000
0x0086e4 0x00000000
0x0086e8 0x00000000
0x0086ec 0x00000000
0x0086f0 0x00000000
0x0086f4 0x00000000
0x0086f8 0x00000000
0x0086fc 0x00000000
0x008700 0x00000000
0x008704 0x00000000
0x008708 0x00000000
0x00870c 0x00000000
0x008710 0x00000000
0x008714 0x00000000
0x008718 0x00000000
0x00871c 0x00000000
0x008720 0x00000000
0x008724 0x00000000
0x008728 0x00000000
0x00872c 0x00000000
0x008730 0x00000000
0x008734 0x00000000
0x008738 0x00000000
0x00873c 0x00000000
0x008740 0x00000000
0x008744 0x00000000
0x008748 0x00000000
0x00874c 0x00000000
0x008750 0x00000000
0x008754 0x00000000
0x008758 0x00000000
0x00875c 0x00000000
0x008760 0x00000000
0x008764 0x00000000
0x008768 0x00000000
0x00876c 0x00000000
0x008770 0x00000000
0x008774 0x00000000
0x008778 0x00000000
0x00877c 0x00000000
0x008780 0x00000000
0x008784 0x00000000
0x008788 0x00000000
0x00878c 0x00000000
0x008790 0x00000000
0x008794 0x00000000
0x008798 0x00000000
0x00879c 0x00000000
0x0087a0 0x00000000
0x0087a4 0x00000000
0x0087a8 0x00000000
0x0087ac 0x00000000
0x0087b0 0x00000000
0x0087b4 0x00000000
0x0087b8 0x00000000
0x0087bc 0x00000000
0x0087c0 0x00000000
0x0087c4 0x00000000
0x0087c8 0x00000000
0x0087cc 0x00000000
0x0087d0 0x00000000
0x0087d4 0x00000000
0x0087d8 0x00000000
0x0087dc 0x00000000
0x0087e0 0x00000000
0x0087e4 0x00000000
0x0087e8 0x00000000
0x0087ec 0x00000000
0x0087f0 0x00000000
0x0087f4 0x00000000
0x0087f8 0x00000000
0x0087fc 0x00000000
0x008800 0x00000000
alzhao
September 14, 2017, 11:59pm
12
I am not sure what you mean. Pls specify.
