Power Requirements
Hi there,
I am traveling to Brazil with my flint 2 and was wondering if it is fine to plug my router into a 220v power outlet? If not, any recommendations for how I can manage the power input? I am travelling from Canada for context.
That depends on the power adapter supplied with the device. If it says it can take that voltage then you’re fine :slight_smile:
Hello, the adapter supports 100Vac~240Vac, so using 220Vac is not a problem.
