Recently I’ve bought 2 units GL_MiFi V1 and bypass the power on button. Is there any solution to power the device by using 5V or 3.3V onboard input point. Thanks
you mean the mifi with case or bare board? I think you can power up using 5V. Please let me know the version of PCB. You can check the printing on the PCB, where PCIe module will be mounted.
Hi! I managed to power up by using 5V power supply and the pinout arrangement is in reverse direction.
