Any idea how to enable PPPoE offloading with the IPQ series (Slate/Flint)?
It’s very common in Europe and Middle East to use PPPoE for 1Gbit+ GPON unfortunately.
Thanks.
Thanks.
Do you mean the current PPPoE is slow? or high CPU usage?
@alzhao The current PPPoE performance on Slate AX is well capable of going close to a gigabit but with bufferbloat (higher latency), I’ve managed to get it working with the NSS by looking at the IP806x patches at OpenWRT and making a custom build, the CPU is now at ~20% with a tiny latency increase on full gigabit load.
Hi, do you have a firmware to test, could you share the patch?
Hello, just saw your message, I simply followed your instructions at README in gli-infra-build for AXT1800 but enabled qcom-drv-nss-pppoe in menuconfig and that’s it.
Here are the counters that show that it’s working:
cat /sys/kernel/debug/qca-nss-drv/stats/pppoe
#pppoe base node stats start
pppoe_rx_packets = 420679 common
pppoe_rx_bytes = 550615955 common
pppoe_tx_packets = 0 common
pppoe_tx_bytes = 0 common
pppoe_rx_dropped[0] = 0 drop
pppoe_rx_dropped[1] = 0 drop
pppoe_rx_dropped[2] = 0 drop
pppoe_rx_dropped[3] = 0 drop
pppoe_short_pppoe_hdr_length = 0 exception
pppoe_short_packet_length = 0 exception
pppoe_wrong_version_or_type = 0 exception
pppoe_wrong_code = 0 exception
pppoe_unsupported_ppp_protocol = 0 exception
pppoe_disabled_bridge_packet = 0 exception
0. nss interface id=31, netdevice=pppoe-wan
#pppoe session node stats
pppoe[0]_rx_pkts = 420620 common
pppoe[0]_rx_byts = 547241746 common
pppoe[0]_tx_pkts = 0 common
pppoe[0]_tx_byts = 0 common
pppoe[0]_wrong_version_or_type = 0 exception
pppoe[0]_wrong_code = 0 exception
pppoe[0]_unsupported_ppp_protocol = 6 exception
Wi-Fi doesn’t seem to be offloaded, not sure how to test/enable that.
To add, the patch I used previously had the same result. (applied to nss-drv)
And no memory leaks so far.
Edit2: Noticed that the UDP VPNs and QUIC perform much better too.
Here is the kmod file for testing only, extract with tar zxpvf
and tar xvf
for data.tar.gz , copy /etc /lib
to root.
If the slate refuses to boot simply reset or unbrick.
May also work with the flint if the kernel version is equal.
kmod-qca-nss-drv-pppoe_4.4.60+153998d70fdba508a59a28c13a606032cbf32686-2_arm_cortex-a7.ipk.zip (3.7 KB)
