Print server with GL-A1300 extender mode
How can I connect my router GL-A1300 to a printer with a USB?
I dowloaded from luci the driver for the print server, also i have to use my router as a extender.
Any tips , or informations about this one?
We're not entirely sure about your specific use case, but assuming you want to connect a printer via USB and enable network shared printing.
Typically in this scenario,
  1. You need to install the printer's corresponding driver (you mentioned it's already installed)
  2. Install and configure the Print Server application, such as luci-app-usb-printer or luci-app-p910nd
    Here's a user guide from the OpenWRT community for your reference: Testing to determine if you are a bot!
Please note that in extender mode, you must use the IP address assigned to the GL-A1300 by the upstream router to access the printer server.
