Hi, i am trying to setup my GL-SFT1200 as a nordVPN gateway in my existing infrastructure.
At this moment i have assigned the role access point to the router.
When i do so, the application Nord VPN disappears. When I go in the openwrt config and try to update the applications list, i get the following errors.
Downloading https://fw.gl-inet.com/releases/v18.06.5/kmod-4.3.2/siflower/sf19a28_nand/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v18.06.5/kmod-4.3.2/siflower/sf19a28_nand/Packages.gz
Downloading https://fw.gl-inet.com/releases/v18.06.5/packages-4.1/siflower/glinet/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v18.06.5/packages-4.1/siflower/glinet/Packages.gz
Downloading https://fw.gl-inet.com/releases/v18.06.5/packages-3.6/siflower/packages/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v18.06.5/packages-3.6/siflower/packages/Packages.gz
Updating database.
Database update completed.
Failed to establish connection
Collected errors:
opkg_download: Failed to download https://fw.gl-inet.com/releases/v18.06.5/kmod-4.3.2/siflower/sf19a28_nand/Packages.gz, wget returned 4.
opkg_download: Check your network settings and connectivity.
opkg_download: Failed to download https://fw.gl-inet.com/releases/v18.06.5/packages-4.1/siflower/glinet/Packages.gz, wget returned 4.
opkg_download: Failed to download https://fw.gl-inet.com/releases/v18.06.5/packages-3.6/siflower/packages/Packages.gz, wget returned 4.
I can reach the site from within the router/access point:
PING fw.gl-inet.com (108.156.60.66): 56 data bytes
64 bytes from 108.156.60.66: seq=0 ttl=250 time=7.585 ms
64 bytes from 108.156.60.66: seq=1 ttl=250 time=7.492 ms
64 bytes from 108.156.60.66: seq=2 ttl=250 time=7.511 ms
64 bytes from 108.156.60.66: seq=3 ttl=250 time=7.542 ms
Any idea?
