Problem using VPN client
I solved it! - well sort of, but I don’t understand why.
In the custom DNS settings there is an option to use DNS over TLS (Cloudflare or NextDNS)
I selected that and it has solved 99% of the issue. (for some reason it still blocks my email server but other web sites are all running OK)
That does suggest it was a DNS problem and something different between the Linux & Windows versions of OVPN
Thanks for all your help :smile:
I may be back when I try setting up the MT300 as a VPN server :grimacing:
