harlie
June 14, 2016, 9:37pm
I have a Problem witth my AR150 (FW: 2.19) and OpenVPN. The AR150 could not connect to the VPN Server. I have a .ovpn File and a .pem CA-Cert.
This configuration works fine with OpenVPN for MacOSX (Tunnelblick) and OpenVPN Client for Android.
There is a “dev tap” in the .ovpn…
I am not the owner of the VPN Server.
Greetings from Germany
Jan
You may want to start with this note:
harlie
June 15, 2016, 12:52am
4
I have read this. In this Thread it says to change the /etc/config/network entry
“config interface “VPN_client””.
from tun0 to tap0,
But this file has no such entry.
Greetings
Jan
alzhao
June 15, 2016, 10:19am
5
@Harlie , as you use tap and we don’t have such configuration for testing. If you can send me a real ovpn for testing, that would help. You can change your name, password and pem after the test.
