Puli AX (GL-XE3000) IMEI change
I am considering purchasing the Puli AX (GL-XE3000). Is it possible to change the IMEI on the Puli AX (GL-XE3000) using AT commands, just like on the GL-E750V2?
Thanks
Yes, no issue changing it. Just remember to check it and write it down before you change it so you can easily set it back if needed.
Thanks for your answer
