In the absence of the VPN switch on the Puli (XE300), is there a way to force the VPN to connect as soon as an Internet connection is available via Luci interface?
Thanks,
Rob.
Thanks,
Rob.
I don’t understand. If you enable vpn, doesn’t the vpn connect when internet is available?
You want to disable vpn when Internet is not available?
No - the VPN doesn’t automatically establish on the Puli - you have to tap the connect button under VPN options.
On other models, there is a button on the side which you can configure to turn on the VPN - this isn’t available on the Puli.
Maybe you can use the smartphone app to turn on or off the vpn. It is very easy.
