Hi, can someone please help on why I cannot set up Wireguard Server using PureVPN Config File. In the Wireguard Server it is showing The client is starting, please wait…“” Below are the logs I am getting. Can you also advise the device OS?
You should be loading the PureVPN config file into the WireGuard Client, not the WireGuard Server.
PureVPN is a VPN provider that hosts their own VPN servers (I used them previously). Their PureVPN config files are to be used by client devices in order to connect to their own VPN servers.
Sorry, this was my mistake, a typo error. Actually, I have uploaded the file on the WireGuard client. The above issue is from the client and not the server.
Can you show the PureVPN config file (with private info redacted) and the complete portion of the system log from before you started the WireGuard client to after it has failed.?
In the below config, PureVPN support added /24 after the Address and changed the Endpoint server address to the IP address. In the command prompt using nslookup can find the IP address. When downloading the manual config from the PureVPN site, these addresses need to be changed,
Ouch. So their conf files or their config generators aren’t up to date. How bothersome. It’s still not the strangest thing I’ve seen VPN providers do for WG conf, though.
