Is there any plans to upgrade python3 package to 3.7?
On OpenWrt there is a 3.7 version but not accessible from GL-S1300.
If not is it possible to install it in some way?
I don’t know if there are any plans to upgrade the package at the moment, but if you need it now, you can compile it using the GL SDK from here:
You can also check out this thread to understand the build process for packages in OpenWRT a bit better:
You can apply that to any package.
