I am almost done setting up my VPN. I had a question about which IP I should be using on port forwarding rules on my main router. If I use my GLI.net IP (public) it will change I believe at some point which will eventually block me. Do I Use the IP that is in the wiregaurd section of the admin page on my main routers port forwarding rules? I am a bit confused on this topic.
that is correct. I have a router above the wiregaurd server router. I see a bunch of options for my MAC address. Does it matter which one I select? I am connecting via PPPoe to my main router.
