New GL.iNet user here. Really loving the forum discussions (why I chose the router) and also my Flint 3 (GL-BE9300). While the Flint 3 doesn’t have true OpenWRT support due to the chipset, it’s a great router and I’m okay giving up OpenWRT just for a solid product within my price range.
Question regarding CPU Average Load… I’m coming from an ASUS BE router on the same WAN connection and roughly the same client load, but the steady ~2.0 load seems very high to me given my setup.
The observation
The System Overview dashboard shows CPU Average Load sitting steady around 2.0 to 2.1 (never lower) on a 4-core system, even with no additional plugins, no VPN, no AdGuard Home, and DPI Engine disabled. Hardware Network Acceleration is enabled. On the previous router (ASUS RT-BE90U, same client count, same encrypted DNS setup), reported CPU usage sat around 10% percent, so this felt like a big jump.
I SSH'd in to check more directly:
cat /proc/loadavg
2.00 2.03 2.00 1/215 6973
top -n 1 -b
Mem: 557472K used, 325616K free, 3616K shrd, 56952K buff, 92372K cached
CPU: 0% usr 2% sys 0% nic 97% idle 0% io 0% irq 0% sirq
Load average: 2.01 2.02 2.00 2/216 8288
So actual CPU usage is near zero (97% idle), but load average is locked at ~2.0 regardless. Nothing in the process table shows meaningful %CPU, the process list is dominated by idle daemons (dnsproxy, hostapd, nginx, netifd, etc.) all sitting at 0%.
Scanning the process list, I noticed a few threads in D state (uninterruptible sleep):
29152 2 root DW 0 0% 0 0% [kworker/u8:2+ec]
1568 2 root DW 0 0% 2 0% [kworker/u8:6+ec]
And the NSS/PPE hardware offload management threads are present and active:
7847 ecm_sfe_ipv6_wo
7846 ecm_ppe_ipv6_wo
7787 ecm_ppe_ipv4_wo
7788 ecm_sfe_ipv4_wo
My guess is the load average figure is being inflated by these offload/ECM threads sitting in a wait state, rather than reflecting genuine CPU work, since actual usr/sys time is near zero. But I wanted to check with people who know the NSS/PPE offload driver better before assuming that's the explanation.
Questions
Is a load average of ~2.0 at true idle (0-3% actual CPU usage) expected behavior with hardware Network Acceleration enabled on this platform, tied to how the ECM/offload threads report state?
Is the System Overview dashboard's "CPU Average Load" metric intended to be read as a Linux load average (relative to core count) rather than a direct percentage? It's not labeled either way on the dashboard itself, which made the ASUS comparison a bit misleading at first (ASUSWRT shows direct percentage, not load average).
Is there a way to confirm hardware offload is actively handling flows rather than falling back to software forwarding, short of what's visible in
top?
Happy to pull additional diagnostics if useful (dmesg, ecm module status, etc).
Setup for reference:
GL-BE9300 (Flint 3), firmware v4.9.0
WAN: PPPoE, VLAN 100, MTU 1492
DNS: Encrypted DNS, Quad9, DNS over TLS
WiFi: MLO (2.4/5/6 GHz) + separate 6 GHz, 5 GHz, 2.4 GHz bands, all WPA3-SAE, plus one 5 GHz guest network, mixed
7 online clients at time of test (5 clients on MLO, 2 client on 5G guest)
Hardware Network Acceleration: enabled
DPI Engine, AdGuard Home, VPN, plugins: all disabled
No Mesh, or repeater setup
Uptime at time of test: ~1 day 19 hours
CPU temp: 64°C / 147°F, fan 0 RPM
