Hello
Im planning to buy either the GL-USB150, or the GL-AR300M.
Which kind of OpenVPN encryption is supported by the preinstalled firmware and what encryption is the hardware of those small devices even capable of?
Thanks in advance.
Hello
Thanks in advance.
I think the default is aes-128-cbc, at that encryption the AR300M is going to get you ~11-12mbps download and upload.
Alright. Do you know if AES-256 is also possible? I really don’t care about speed, because my connection is slow anyway.
Yes, it supports.
I use AES-256-CBC so it definitely supports it.
