Any time that I hold down the "repair or reset" button on my GL-MT6000 router for 3sec, or reboot it, the 2.4gHz guest network is disabled. Is there a way to prevent this?
Sorry. There is no way to change this operation because it belongs to a firmware function.
Press reset for 4 seconds to reset the router default network settings.
Guest WiFi is related to network settings, and its default settings are disabled, if reset networks, it will be disabled.
