I’m managing a couple of Ubiquiti/Unifi based WiFi systems, with30 to 100 AP each.
Sometimes, in specific spots, WiFi coverage is a bit bellow expected levels (-75dB) in rooms where you can’t extend current cabling.
For this, I’m looking for GL iNet devices with the followings specs:
- powered though a USB-C preferably or a Micro-USB plug,
- OpenWRT powered
- at least one very sensitive 2.4 or 5 GHz radio for long range uplink (802.1X)
- one 5 GHz radio for short range downlink (PSK)
- if possible, one external antenna plug compliant with devices like [1]
- one Ethernet LAN port
- easy to buy online
Which device would you recommend ?
Best regards
