Do you have log when the Internet connection loss?
I just bought the MT3000 and I face similar issue. My Vpn connection keeps dropping every few minutes (around 6 mins). Here are my logs
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: OPTIONS IMPORT: peer-id set
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: OPTIONS IMPORT: adjusting link_mtu to 1657
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: OPTIONS IMPORT: data channel crypto options modified
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: Data Channel: using negotiated cipher 'AES-256-GCM'
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: net_route_v4_best_gw query: dst 0.0.0.0
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: net_route_v4_best_gw result: via 192.168.0.1 dev eth0
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: TUN/TAP device ovpnclient opened
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: net_iface_mtu_set: mtu 1500 for ovpnclient
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: net_iface_up: set ovpnclient up
Mon May 29 03:11:51 2023 daemon.notice netifd: Network device 'ovpnclient' link is up
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: net_addr_v4_add: 10.8.0.38/16 dev ovpnclient
Mon May 29 03:11:51 2023 daemon.info avahi-daemon[3716]: Joining mDNS multicast group on interface ovpnclient.IPv4 with address 10.8.0.38.
Mon May 29 03:11:51 2023 daemon.info avahi-daemon[3716]: New relevant interface ovpnclient.IPv4 for mDNS.
Mon May 29 03:11:51 2023 daemon.info avahi-daemon[3716]: Registering new address record for 10.8.0.38 on ovpnclient.IPv4.
Mon May 29 03:11:51 2023 daemon.notice ovpnclient[26186]: /etc/openvpn/scripts/ovpnclient-up ovpnclient 0 ovpnclient 1500 1585 10.8.0.38 255.255.0.0 init
Mon May 29 03:11:51 2023 user.notice ovpnclient-up: env value:route_vpn_gateway=10.8.0.1 daemon_log_redirect=0 script_type=up proto_1=udp daemon=0 SHLVL=1 foreign_option_1=dhcp-option DNS 103.86.96.100 dev_type=tun foreign_option_2=dhcp-option DNS ****** remote_1=****** dev=ovpnclient X509_0_CN=******* remote_port_1=**** X509_1_CN=NordVPN CA8 X509_2_CN=NordVPN Root CA X509_2_C=PA ifconfig_netmask=255.255.0.0 tls_digest_sha256_0=********** daemon_start_time=1685319104 script_context=init ifconfig_local=10.8.0.38 common_name=******* tls_digest_sha256_1=******* tls_digest_sha256_2=******** verb=3 link_mtu=1585 trusted_ip=81.19.223.4 tls_serial_hex_0=****** X509_1_O=NordVPN tun_mtu=1500 tls
Mon May 29 03:11:51 2023 daemon.notice netifd: ovpnclient (26186): udhcpc: started, v1.33.2
Mon May 29 03:11:51 2023 daemon.notice netifd: ovpnclient (26186): udhcpc: sending discover
CloseCopy
The log only shows a successful connection. Do you have log when it disconnects?
Is it stable if you use other OpenVPN client like phone apps?
@hansome I’ve attached the log after it failed to provide an internet connection. The router’s been on for a few days.
logread.zip (20.4 KB)
The log shows the server didn’t respond any packet. Could it be an internet isp issue?
Well if I connect to my ISP directly it works.
I almost wonder if it needs disconnecting periodically because it might overheat.
I could be. I rechecked the kernel.log and found it might be related to wifi. Do you use repeater? And what is the access point model ax1800 repeating?
What’s a repeater? I’m just connecting my GL-iNet router to my regular WiFi network.
