Reloading firewall due to ifup of wgclient (wgclient)
I have been using my Flint 2 and Slate 7 fine for the last 4 months but today I was disconnected while on a call with a client and have not been able to connect properly since. I have tried troubleshooting my regular connections at both locations and they are working fine, also tried changing lan cable just to make sure and tested connections on my cellphone with wg client and got the same issue. I have not changed anything in the server or client, this is my log on my client (slate 7). Has anyone experienced this before?
Wed Nov 19 15:59:01 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Wed Nov 19 15:59:06 2025 daemon.notice netifd: wgclient (6906): Try again: `vuc9553.glddns.com:51820'. Trying again in 1.00 seconds...
Wed Nov 19 16:09:39 2025 daemon.notice netifd: Network device 'wgclient' link is up
Wed Nov 19 16:09:39 2025 daemon.notice netifd: Interface 'wgclient' is now up
Wed Nov 19 16:09:39 2025 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin CONFIG_LIST_STATE= J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Hideme IPVanish Mullvad NordVPN PIA Surfshark FromApp group_5964 group_8931 group_8250 group_1216 group_4183 group_3502 group_6468 group_9435 group_2079 peer_2001 peer_1729 CONFIG_cfg030f15_ports=
Wed Nov 19 16:09:40 2025 user.notice firewall: Reloading firewall due to ifup of wgclient (wgclient)
The logs indicate that the WireGuard client is unable to complete the handshake.
Please try the following steps to narrow down the cause:
  1. Confirm that the Slate 7 has a stable internet connection. If the router cannot reach the internet, the VPN connection will fail.
  2. Test the same WireGuard configuration file on a mobile device connected to the same network as the Slate 7.
    • If the phone also fails, the problem is likely related to the network environment or server.
  3. As a further check, connect your phone to a different network (mobile data or another ISP) and try again.
    • If it works on an external network, your current ISP may be blocking UDP traffic required for WireGuard.
    • If it fails on an external network, please check whether the Flint 2 - the WG server works fine or not.
