Hay i notice you have removed version 1 of the API from online. Is it anywhere i can still find it?.
The routers that often come from the shops here have legacy firmware and my app checks the firmware version then automates upgrade but need to make use of API v1 sometimes.
We decided to encourage users to upgrade to the latest firmware versions for API support. There are a lot of issues that were fixed with older firmware’s, so its hard to offer support if you need to struggle with old bugs as well.
The error codes are now in each API section, in the “code” field. If you find any missing codes, let me know
