The bug of not displaying saved wifi has been fixed in the v2.6.0 release
Yesterday while sitting on a bus i found, that the App-bug might be still there, while connected via app and not connected via wifi.
But i was not able to reproduce the problem. Maybe somebody else can test.
I apologize for my incomplete reply. I am using a GL-X3000 that is currently stuck on "Getting ..." when trying to setup as a repeater in my current location. I have adjusted a variety of settings that are covered in this topic and another I found in another forum section. My router is running the latest stable firmware (4.4.13). I looked at the release notes for the latest beta (4.7.1) but I do not see any mention of this problem being fixed in that version.
I am not sure what the op24 firmware is or where to get it.
The problem you mentioned appear on MT3000/MT6000 and it is fixed using op24 firmware.
Unfortunately for X3000 it also has this problem but don't have op24 firmware, due to that X3000 firmware is too complicated.
Ok I understand. Is the problem confirmed with the X3000 and being worked on? Do you need me to try anything else to assist?
X3000 use the same chipset as MT3000. So it has the same problem.
If for repeater you can uss static IP, that may work. But I am not sure if X3000's firmware support static IP yet.
I was able to configure a static IP today to get it to work. I will keep an eye out for any updates.
Thank you.
I have the exact same issue and have been working with support to resolved it. But finding this thread probably explains what the problem is. I currently own two GL.iNet devices, MT3000 and X3000, so that means neither can connect to the repeater I'm trying to connect to. :frowning:
This is a major issue for me though as in my case this repeater is for my home Internet connection because I live in a building that provides the internet via WiFi (no hard wired connection).
As such I'm wondering @alzhao are you close to a fix for this? Thank you!
For MT3000 the OP24 firmware should not have this issue. GL.iNet download center
Also you can try the 4.8 firmware and for repeater you can use static IP address so should also work.
Thank you! With v4.7.5-op24 firmware my MT3000 is connected again!
I tried v4.8.0 beta, which looked very nice, I love the new repeater connection UI. But it didn't work for me, I had the same issue. I didn't try setting a static IP address with 4.8.0 beta, as I wasn't sure how. :slight_smile:
