Replacing an ISP fiber box with a personal router and compatible ONT
Hello
I have one last question, the sfp+ port of Flint 4, supports both the GPON and XGS PON ??
Because for me I will have a connexion of 2gbs with an sfp huawei MA5671A, that I want to connect it directly to the Flint 4 sfp+ port
Thank you
The SFP+ port on Flint 4 is a high-speed pluggable interface; GPON or XGS-PON functionality itself is provided by the ONU/ONT stick.
Before proceeding, we would recommend checking with your ISP whether they allow customers to use their own SFP+/PON ONU modules on the fiber connection.
If they do, please also confirm which PON/ONU Stick models are supported or approved by your ISP, as the connection may depend on their network and authentication requirements.
Thank you for your understanding and support.
Thank you for your reply.
I am already using a Huawei MA5671A GPON ONU with my ISP,and I have successfully configured it. The module authenticates correctly, establishes the GPON connection, and I have full Internet access.
My main question is whether the Flint 4 SFP+ port is compatible with this type of GPON ONU, since I’m currently using it through an external SFP-to-RJ45 media converter. I’d like to know if I can simply insert the Huawei MA5671A directly into the Flint 4’s SFP+ port and expect it to work the same way.
Another question : if my ISP upgrades me from GPON to XGS-PON in the future, would I simply be able to replace my current GPON ONU with a compatible XGS-PON ONU and continue using the Flint 4 ?
Thank you!
Thank you for the clarification.
The Flint 4 SFP+ port can be used as a WAN interface with an SFP+ ONU stick. We have tested most commonly used SFP+ ONU modules, and they can be properly recognized and used with Flint 4.
Yes. If your ISP upgrades the connection from GPON to XGS-PON, your current GPON ONU stick would also need to be replaced with an appropriate XGS-PON ONU stick.
Thank you for your support.
