(Request) Windscribe - Glinet App Login Improvements
Few things Ive noted. Logging in to Windscribe via the glinet is great but not without its flaws.
When we "login" to use Wireguard a key pair is automatically generated, this is fine however Windscribe has a max key pair limit of just 5, so let's say we login / logout via the glinet app or say the glinet app decided to clear its storage and we needed to login again, the glinet app will then create another new key pair. Now as you can imagine, eventually we will hit the key pair limit and have to go to Windscribe to delete the key pairs in order to login again.
Windscribe unfortunately has no real easy key pair management other than to delete them all. This causes me problems as I have a dedicated key pair that I never want to delete but unfortunately I need to in order to allow my glient app to "login"
My guess is that the "login" option on the glinet Windscribe section is in fact "generate key pair" on the Windscribe API and glinet then stores the key pair, modifies the server location URL and recreates the key pair every time, until obviously we logout and login in again, creating a new key pair.
So what I'm trying to achieve is some way we can assign a key pair to our routers. A way we can always say this is the key pair even if we logout and back in or the options to choose existing key pair / create new key pair? This would then stop the need for creating multiple key pairs over and over again we not needed.
And the last improvement would be for multiple devices. Say I have two routers showing under my glinet app. Because I'm am logged in to Windscribe already, the key pair is already assigned and now when I want to change the VPN location on router 1, the key pair gets updated and transfered to router 1 BUT if I then go to router 2 and I want to choose Windscribe I can't make another keypair or choose different key pair because I'm already logged in / there's no way to select key pair(s) so the same key pair is actually used between both devices which would cause issues if both of the devices are using the Same location / key pair
Thank you for taking the time to share such detailed and valuable feedback about your experience with Windscribe integration on GLiNet routers.
Windscribe does not have a relevant API to integrate in router firmware to connect. In addition, R&D plans are arranged relatively tightly, and there may be no relevant plans for the time being. Sorry.
We truly appreciate users like you who provide deep technical insights—this helps us understand real-usage scenarios and challenges.
Hi @bruce I wasn't requesting anything in regards to integrating in the router firmware itself, althought that would be great as Windscribe is a big VPN provider now. My request is aimed at the already integrated Glinet mobile app that allows us to use a Windscribe login "Profiles in Phone"
I believe the integration that is currently implemented could be better with what I have suggested. If possible please take another look or forward for a potential rework.
No problem, I highly recommend glinet products and any feedback I can share is no bother. Thanks again.
Thanks.
I will forward to PM team to check.
