I have an issue with the default EDIDs that are provided. I have need to be able to run at 1920x1080 30HZ but I can't figure out how to get any EDIDs to work. I copy/pasted the edid-decode hex from a monitor that is listed at 1920x1080, but it keeps coming back saying 3840x2160.
Any help that can be provided would be greatly appreciated.
I will try to make a 1920*1080@30FPS EDID and I will reply you if any progress is made.
Hi, could you please try this one
00FFFFFFFFFFFF0006B3B22401010101
211E010380351E780EEE91A3544C9926
0F505421080001010101010101010101
010101010101011D801871382D40582C
4500132B2100001E000000FF004C384C
4D51533037353339320A000000FD0018
3C1E5A1E010A202020202020000000FC
00524F47205047323438510A202001CD
02031AC147901F041303120123090701
8301000065030C001000000000000000
00000000000000000000000000000000
000000000000000000000000000000C1
You can try the edid above, I did a simple verification
