So i was trying to flash some firmware to a GL-AR150 and i must have done something wrong because now i cant connect to the device. Before i attempted this i made a back up for the inevitable. Is there a way to restore from the backup through the USB port? I happen to have BIOS chip jumper cables though ive never done that and dont know how to. I’ve tried to look it up and im not sure whatt drivers i need. i am currently using Fedora 35 though i have access to other OS’s. I dont believe the device is bricked because the LEDs sill turn on. Help would be greatly appreciated.
If LEDs are still on, you can press and hold the reset button for 10 seconds to reset the firmware.
You should see the LED flash after you press down the reset button.
