RM10 - screensaver misaligned
After upgrading to V1.9.1 release1, the screensaver date is not aligned to the center and part of the text is cut out.
+1
Upgraded from 1.8.x and facing the same issue.
When can we expect this to be fixed? Can you give us a ‘manual workaround’? Assuming there is some CSS file that can be edited via SSH?
This issue will be resolved in version 1.10. I'm not sure if there is any manual fix for this problem. Probably not.
