Router: GL-AX1800
I’d like to connect all the vpn server traffic so that it routes out to a specific LAN port on the router.
Is this possible?
Router: GL-AX1800
Is this possible?
Sorry I cannot understand what you mean. Can you describe in another way?
Does it make sense?
So you want to set up some Site-to-Site network, so that the devices in the vpn client and local LAN can talk to each other.
You may not route all the traffic, but only need the device at each side can talk to other device via IP address.
One way to try is enalbe this option “Allow Remote Access LAN” in the vpn server.
Another way is to use Tailscale.
