Router BSSIDs
Where in the file directory can I find BSSIDs for all router networks for scripting purposes? This would be extremely helpful? I checked /etc/config/system but the mac_addr field is not present.
In OpenWrt you should utilise uci instead of handling with files manually.
Try uci show to get all settings and variables.
https://openwrt.org/docs/guide-user/base-system/uci
At least on the MT6000 you can’t read the BSSID (nor you can change it) - might be because of the closed source driver from MTK.
ip a will at least show the radios and the MAC there.
