trying to access my devices
I have a GL-MT300A and a GL-AR300M and have the same problem on both
the GL-MT300A was working fine until I tried to upgrade with openwrt-ar300m-nand-3.024.tar via the web interface
I power it while pressing the reset button for 10 seconds but it is not working: the wifi network disappears after the reset but after a power off/on it is back to its previous state.
I followed the recover video from https://docs.gl-inet.com/en/3/video/tutor/#how-to-recover-glinet-mini-router-by-u-boot-failsafe
but the router is not assigning any ip I get a self assigned IP 169.254.123.173
that is not normal I should get an ip
so I cannot connect to the router at all
Any idea how I can recover to factory default ?
