Router-VPN Provider Compatibility
The GL-AXT1800 is actually NOT on ExpressVPN’s list of supported routers, and there is no client configuration file that can be downloaded for it there. (And even if it WERE supported, I think you’d be downloading an entire router firmware, not just a VPN client conguration file.)
