Run autoupdate script when new IP discovered (GL-MT300N-V2)
Is there a way to run a wget or other command to update my DNS service of a new detected IP address. It seems possible with DD-WRT but I can’t figure out how to get this router configured (open-wrt I’m assuming).
client ip connecting to the gl router?
/tmp/dhcp.leases
also tertf in /tmp has info
The router connects to the client ip (modem).
are you by any chance running NextDNS?
I’m not but if there is an easy way to get it setup using NextDNS I’m willing to switch
yes. NextDNS setup page you can update from GL’s DDNS service here.
so set up this DDNS first and update from their ddns address
