When I change the name of the wifi network to something else, it works okay, but as soon as I disconnect the router and plug it back into the wall, it resets to factory settings… how do I get around this? Is this a defect to my product?
Firmware version is the default that came with it out of the box 3.023 compiled on 2019-05-23.
I only changed WiFi SSID and password first for 2.4ghz and password (using hit Modify, then Save). Router disconnects and restarts.
I then connect to the new SSID, then modified the SSID for the the 5Ghz (using hit Modify, then Save).
After a day or so… all I did was just unplugged power adapter from wall. Then replugged in.
When I do that, all the settings reset to factory and it asks me to define admin password, etc.
I redefined everything using the same process above and it works fine… but then I unplugged the power adapter from the outlet and replugged in, and it forgets all the settings and auto-resets back to factory settings again.
How do I enter commands into the router? Is this something I can access through admin control panel? If not, please provide step by step instructions what I need to do.
No, like I said. I just unplugged power cable and replugged it in. No buttons were hit. Just recently, there was a power outage and the router settings reset back to factory default. This is a very troubling problem, please help.
