Safe sufer firmare on GL-ax1800
installed safe surf firmware on GL-AX1800 flint model
now when trying to erase it will not erase
stuff i did
pull power push reset put power back til light goes white let go wait
add in ip 192.168.1.2 and sub 255.255.255.0
scan network goes to ip 192.168.8.1 and safe surf shows up again
just want to go back to oem firm wear that came out of the box
In my world, if you are using a different firmware, this project also should provide a tutorial/way back.
But the original firmware has a sledgehammer, the uboot method: Debrick via Uboot - GL.iNet Router Docs 4
