Has anyone successfuly usb tethered a Samsung Note 8 to GL-AR150? I have used multiple USB cables with no difference. Any help would be super!
Hi, the Android phone should enable USB tethering by manual in Setting.
I have done all the setup phone side. The AR150 doesn’t see the connection. I just tried it on a MT300N and it connects and runs like a charm. So what is different about the AR150?
Which version of the firmware do you use?
