Where is the “Saved Networks” repeater configuration stored on the device?
wwan saved networks are stored in /etc/config/ssids
Are all saved networks stored there? As best I can tell only the currently connected network is.
I can’t be sure it’s the only place where all wwan/repeater network connection info is held. but as a starter you can scan and connect to a different wireless network other that the one you are connected to and after a succesful connection you can then view /etc/config/ssids and confirm with admin_panel/internet/saved_networks
