Model / firmware: GL-BE9300, firmware 4.10.1 (OpenWrt 23.05-SNAPSHOT, kernel 5.4.213)
Steps to reproduce: Go to Network → Subnet in the left sidebar, click Edit on the relevant network (e.g. Main Network), then under Address Reservation click Add and save a new MAC/IP reservation.
Symptom: Saving a DHCP static lease/reservation this way causes a brief (~8–9 second) outage for all wired LAN clients, plus a Wi-Fi client kick/re-auth. Reproducible every time, confirmed 3 times via syslog (forwarded to Loki).
Root cause (confirmed from logs):
- Saving a reservation restarts
dnsmasq2–3 times and the kernel re-registersbr-lan(tertf: br-lan registered, add it). gl_util: kick_ap_clients_by_network: network=lanfires, kicking all Wi-Fi clients.kmwanlogsconfig json str={ "op": 6, "data": { } }at the same moment.- Immediately after, the kernel logs
rtl8372-mdio 90000.mdio:1d: lan1 link down, thenbr-lan: port 1(eth1.1) entered blocking state→forwarding state, then ~8s laterlan1 link up, speed 2500, followed shortly bylan3 link up, speed 2500. - No
netifdifup/ifdown events are logged forlanat any point — this is not a normal/etc/init.d/network reload. The flap happens at the switch-chip (RTL8372N) level, below netifd.
This looks related to the known issue in this thread, where eth1.1 is br-lan’s only wired member aggregating all physical ports via the RTL8372N switch — any port state change there seems to ripple to the whole bridge. Here, though, the trigger is software (kmwan’s op:6, which fires from a DHCP UI save, not a WAN event), not a physical cable pull.
Workaround confirmed: Adding/editing the exact same reservation via SSH only (uci add dhcp host; uci set ...; uci commit dhcp; /etc/init.d/dnsmasq reload, bypassing the web UI entirely) does not trigger kmwan, tertf, the Wi-Fi kick, or any port flap — confirmed by comparing syslog from the same action done both ways.
Questions for GL.iNet:
- Why does editing an LAN-side DHCP reservation notify
kmwan(a WAN failover/multi-WAN daemon) at all? - Is
op:6meant to re-scan all netcells/interfaces on any config change rather than specifically WAN changes? That would explain both this report and the otherkmwanthread about WAN teardown on DHCP renewal. - Could the UI’s “apply” path for DHCP host entries skip whatever triggers
kmwan, matching what plainuci+dnsmasq reloadalready does safely?
