How do I script reset each evening, and auto connect all USB or ethernet tether? I am using this script:
# /etc/init.d/cron enable
# nano /etc/crontabs/root
00 01 * * * reboot
# /etc/init.d/cron restart
I can’t confirm if it works
00 01 * * * reboot
You’ll potentially run into boot loops with this, as time can go backwards at boot with a device without a “battery” RTC.
My first suggestion is that “reboot” is a sledgehammer. Finding and resolving the reason you think you need to reboot is preferable. Restarting the single service that is problematic, when it is problematic, is a better fall-back.
If you truly need to reboot the router (and I don’t think you do, mine run for months on end, usually until the next power-utility outage or I upgrade them), see https://openwrt.org/docs/guide-user/base-system/cron#periodic_reboot_of_a_router
hi how do I move scripts from my PC to the root of the router?
scp
is the common way to copy files over SSH. Here’s one reference on using scp
on Windows (I can’t comment on options, as I don’t run Windows)
https://success.tanaza.com/s/article/How-to-use-SCP-command-on-Windows
